Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree1Likes
Thread: Question: HKS SSQV - Skyline GTR R32
    GTRCer Nvdgtr's Avatar
    Apr 2011
    Brantford, on
    654
    I tried searching and couldnt really find the answer im looking for!
    I'm thinking of getting some hks ssqv bov for my skyline gtr r32.
    Want to make sure I have this correct! I can install the adapter to the bov and it will bolt right up to where the existing stock bovs are correct?
    Is there a dofference between the black and silver hks ssqv bov?
    And will I have any issues or no?
    I'll have no issues that these won't be recirculating correct?
    Plan to install these this winter!
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    5,175
    I have an HKS ssqv2 bov that comes with the correct pipe is that direct boot on to the r32 gtr. Pipe is black and the bov is the limited black edition. Pm formdetails
    lol
    Apr 2011
    Brantford, on
    654
    Anyone..
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    319
    I don't know about this exact kit personally but if you are running a factory ecu then if you run an atmospheric setup, then you will run rich between shifts. The factory tune takes into account the air coming back from the recirculating valves with the stock setup, and dumps a little extra fuel to make up for it. if there is no air then you have a rich condition. Not a huge deal your not gonna destroy your engine. You may just get some backfire if your banging through the gears and might notice a bit of fouling on your plugs quicker than normal.
    Apr 2011
    Brantford, on
    654
    Quote Originally Posted by gtrjerry73 View Post
    Good to know! Thanks, I plan to get it tuned next year. Just unsure what tune to get..
    Mar 2011
    Toronto, Canada
    108
    do Not use blow off valves on a gtr, there is a reason why it is recirculated, once a bov is installed the car will stall and not idle correctly.
    i have pushed the stock recircs over 500whp, and install after market recirc's on anything above that power goal.
    MAF's and Bovs are a bad combination, plus you loose response between shifts with bov's
    GTRCer quadracer111's Avatar
    Dec 2009
    Martensville, SK
    1,095
    Tons of people have good luck running one vta (like a ssqv) and leaving one stock one recirculating. This helps with the stalling and running rich.
    Sent from a potato
    BNR32- Sold
    1998 Evolution V
    Apr 2011
    Brantford, on
    654
    If I were to install these and then had a tune would that work? Or just stick with stock ones
    Mar 2011
    Toronto, Canada
    108
    I would stick with the stock ones personally unless i was running 600whp then i would either run aftermarket recirc's or at that point a haltech management system running map sensor, at which point you can run all the bov's you want.
    it would be a bad idea to sacrifice drive ability for a whistle sound.
    MarusGTR likes this.
    GTRCer cory's Avatar
    Jul 2010
    Newfoundland
    267
    I moved my bov to right after the turbos before the intercooler and it stopped my stalling issue all together... I guess the intake it still getting a bit of air that's in the intercooler
    95 R33 Gtr
    RICE - Race Inspired Cosmetic Enhancement
  1. LHD Skyline Insurance Question
    By GTReaper in forum Legalese
    Last Post: 03-17-2012, 12:25 AM
  2. Skyline security question.
    By G.T.R in forum General Skyline Discussion
    Last Post: 11-03-2010, 09:02 PM
  3. question bout lisencing a skyline
    By EkostonS in forum General Skyline Discussion
    Last Post: 01-22-2007, 10:36 AM
  4. WOrking under a skyline question
    By rolledmymazda in forum GTS Tech
    Last Post: 04-14-2005, 12:05 AM
  5. Question to Skyline owners
    By BoostedGolf in forum GT-R Tech
    Last Post: 02-11-2005, 11:21 AM
