VEX Performance is doing a Group Buy on Canton Racings Accusump complete setup kit for all Nissan RB26 Engines (and any that support 3/4" - 16 Oil filters)
We will be extending this group buy to Subaru owners as well (Same Price, but different install kit!)
All orders must be made by noon on Friday, January 29, 2010
What is the purpose of an Accusump?
-Pre-Oiling: Supplying oil pressure to the engine before start up for the purpose of lubricating engine components
-Surge Control: Supplying oil pressure to the moving components of the engine when there is a momentary interruption of the normal oil supply
Why should I run an Accusump?
-When you cold start your engine you are able to lubricate your engine before anything even turns over. This dramatically reduces engine wear. Upto 90% of engine wear is done during start-up
-Under high G-Forces in accelerating, decelerating and cornering your oil pump pickup could starve of oil for just a brief second. If this happens and you loose oil pressure it will damage your engine (Sometimes very seriously). Having an Accusump installed will not allow you to loose oil pressure in the event of a briefly oil starved pump.
The bottom line. Apart from the MAJOR benefit of pre-lubricating your engine before start up, if your Accusump ever has to work even once it will save you THOUSANDS of dollars! On an engine rebuild! The more heavily modified the engine, the more you will potentially save. Accusumps come factory on Ultima GTR's and many Lotus's as well. The only setup superior to an Accusump is a full drysump... which costs at least 8X the price of our group buy!
For more information go to http://www.accusump.com/
Group Buy kits include the following:
1 x 24-026 -Accusump 2QT Accumulator
1 x 24-271 -Accusump EPC Electric Actuation Valve 20-25psi
1 x 24-700 -Accusump 3/4" - 16 Nissan installation kit
1 x 24-200 -Accusump Mounting bracket set
If we Sell 1-10 Unit Price is $575 CAD Including shipping to VEX
If we Sell 10+ Units Price is $550 CAD Including shipping to VEX
Orders Confirmed:
1. VEX Performance Rally Car
2. VEX Performance Rotated mount 07 STi
3. Spanky
4. NismoS-Tune
5.
6.
7.
LinkBack URL
About LinkBacks
