With the introduction of our additional AMS R33 V-Spec BBK for the R32 GTR equiped calipers we decided to run a GB for our entire Brake Line for the Skylines before the season begins - while quantities last! (i.e. current inventory)
AMS R33 V-Spec 2 PC BBK (R32 GTR Calipers) - $528 USD Online price. [SIZE="4"]GB special is $468 CDN plus shipping! As an added incentive we will provide a set of AMS Carbon Ceramic Pads (Value $68 USD) FREE! You can choose from the GTR R32 Kit or the Skyline kit as the brackets are different to accomodate the different calipers. Aside from the brackets the kits are the same for both caliper types!/SIZE]
http://amszstore.com/main/product_in...roducts_id=243
• AMS R33 V-Spec front rotor kit (12.75”) is designed for the Z32/R32 GTR equipped with R32 GTR calipers
• 2-piece assembly features an aluminum hat (T6061 aircraft grade aluminum) for reduced weight and improved heat dissipation
• AMS 2-piece rotors shave 1.1 lbs each vs standard sized Z32 1-piece rotors - each pound of unsprung weight is comparable to shaving 4 lbs off the chassis!
• 2-piece design benefits include the ability to allow the cast iron disk to expand/contract uniformly as temperatures rise/fall under hard applications! Minimum distortion leads to increased rotor duration!
• 2-piece R33 rotors increase braking leverage (less force required for the same braking dynamics). Multi-pillar vanes ensure maximum cooling!
• AMS rotors feature 16-slots for aggressive bite! Slots eliminate the possibility of cracking versus crack-proned cross-drilled variants!
• Kit includes: 2 x AMS R33 rotors, 2 x T6061 caliper adapters (R32 GTR) and hardware
* Kit Requires 17" rims to fit!
The above BBK's are serviceable as well! AMS sells replacement rings should they be needed! They are listed on our web-site.
For Both the Skylines and R32 GTR's the AMS Max-Slot Rear Rotors can be fitted! Online price is $175 USD. GB is $150 CDN plus Shipping! For those buying the Front BBK and a set of Max-Slot Rears we will provide AMS Carbon Ceramic Rear Pads for FREE as well! Another $58 USD value!
http://amszstore.com/main/product_in...roducts_id=206
• Multi-slotted (16) rotors for optimal braking under all conditions
• Slots provide maximum bite and performance by dissipating heat efficiently
• Slots provide unsprung weight savings over stock
• Longer life vs X-drilled variants, which develop cracks
• Precision machining and top quality casting ensure OEM and better quality
• Cad-plated for durability
• Compliments the AMS Carbon-Ceramic Pads perfectly!
For non-GTR Skylines the following kit offers the best bang for the buck! Included are F/R AMS Max-Slot Rotors and AMS Carbon-Ceramic Pads F/R! Online price is $348 USD. Special is $299 Plus Shipping!
http://amszstore.com/main/product_in...roducts_id=207
Maximizes the OEM brake system
• Kit include F/R Max-Slot Rotors and F/R AMS Carbon Ceramic Pads
• Stainless steel lines and racing fluid also available
* KIT INCLUDES F&R MAX-SLOT ROTORS, F&R CARBON-CERAMIC PADS
Forms of Payment are Direct Debit Transactions (e-mail), Paypal (add 3% fee), Chq, Money Order, Cash.
PM or e-mail for shipping quotes and provide a full address.
Parts ship usually next business day once payment is confirmed!
Regards,
Vuk@AMS
www.amszstore.com
amszstore@hotmail.com
1(888)888-AMSINC
LinkBack URL
About LinkBacks
