It will be air cooled A1 which you can grind down to 1mm if you want to and it will still retain the same c-scale strength. If you use o1 material on 4mm shim if you grind it down to 3mm the center will be soft. For stock retainer you will require 12mm O.D shims but for aftermarket I will be making them at 12.5mm. The reason being that metal will expand with heat and none of us want a shim to get stuck in a retainer.
edit A2 material.
LinkBack URL
About LinkBacks
