Results 1 to 4 of 4
Thread: Fluidampr Internally Balanced Dampers
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,043
    Any interest in a Fluidampr Internally Balanced Damper group buy for BNR32?
    Pricing would start at $452 and go down from there.
    Fluidampr Engine Dampers are designed to control destructive vibrations which are transfered thru the crankshaft.
    Each time the air/fuel mixture inside a cylinder is ignited, the combustion that occurs creates a torque spike that is applied to the crankshaft through the piston and rod. This torque spike is so severe that it not only turns the crankshaft, it actually twists the crankshaft ahead of its normal rotation and then the crankshaft rebounds. This twisting action is known as torsional vibration. When these torque spikes and forces get into phase with the natural frequency, critical torsional harmonic vibrations occur and can be seriously destructive to the bearings and the crankshaft. Dampers are designed to control those destructive vibrations.
    Critical harmonic vibrations occur numerous times in a engine's operating range. Stock rubber and elastomer-type dampers are frequency sensitive tuned absorbers, and work at only one critical frequency. In the case of a stock rubber damper, it is tuned for a factory engine's critical harmonic vibrations. If you change the mass of pistons, rods, or the crankshaft, you change the natural frequency of the crankshaft assembly; therefore, the stock damper is no longer tuned to the new frequency of vibration, and you may be headed for early failure of expensive engine components. Dampers also create heat while they work, and rubber is a poor dissipator of heat. This heat and the exposure to the elements deteriorates rubber, causing it to crack and change durometer, which then leads to inertia ring slippage, damper failure, uncontrolled torsional vibration, and costly engine parts breakage.
    RightDrive Inc. Parts Manager
    10% off HKS Air Filters!
    GTRCer gtst_type_m's Avatar
    Sep 2009
    kelowna bc
    112
    is this damper the same size as the stock one? also is there a hp rating on these like the ati dampers?
    93 laser sold
    91 skyline gtst totaled
    92 skyline gtr current
    May 2004
    Toronto
    8,043
    Yes, they are the same size as stock. They don't list a HP rating but I can check with them if you'd like
    Sep 2009
    kelowna bc
    112
    that would be great
    93 laser sold
  1. Ztune GB: Ati Super Dampers!
    By MikeM@Ztune in forum Group Buys
    Last Post: 04-16-2011, 03:15 PM
  2. Replies: 5
    Last Post: 02-01-2011, 06:59 PM
  3. GB: ATI Dampers!
    By MikeM@Ztune in forum ZTune Motorsports
    Last Post: 05-07-2008, 05:59 PM
  4. FS: GTR/GTS4 tanabe sus-pro dampers
    By C-unit in forum Parts for Sale
    Last Post: 04-11-2007, 02:45 AM
  5. WTB: Balanced Manifolds
    By pmdawg in forum Parts for Sale
    Last Post: 02-08-2006, 06:49 PM
