Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Ebay oil lines
    Jdc
    Jdc is offline
    GTRCer Jdc's Avatar
    Sep 2010
    Ottawa
    142
    Ebay oil lines
    Must say I am very impressed as it took 5 days to receive these, all fittings are correct, and it was $86 with shipping/taxes/duty. Lines/fittings also seem to be good quality and it came with crush washers for the block tee.
    My question is... kit came with very small 0.8mm restrictors that are supposed to be good for my GT2530RS turbos. These thing just look soooo tiny and I am worried about particles blocking the restrictor and starving the turbo. Am I crazy? Are these perfect for my turbos?
    http://cgi.ebay.ca/Turbo-Oil-Feed-li...ht_1651wt_1139
    Jdc
    Jdc is offline
    GTRCer Jdc's Avatar
    Sep 2010
    Ottawa
    142
    Can someone please move this...
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,050
    i'm glad someone finally started looking at ebay oil lines. I have never held a set in my hand and was curious about the quality. It would save a fortune in russel lines and fittings.
    As for the restrictor yes it should be pretty much a pin hole. If you look at your factory feed its super tiny too. As long as you change your oil regularly you won't have a problem. Oil filter will take care of any debris
    Jdc
    Jdc is offline
    GTRCer Jdc's Avatar
    Sep 2010
    Ottawa
    142
    Awesome! Thanks for the reply. Yes I was a little nervous ordering ebay lines, but they are supposed to be made in Japan and it looks like they are OEM or better quality. Not running water lines right now or I would have ordered the kit that does water and oil lines.
    Jdc
    Jdc is offline
    GTRCer Jdc's Avatar
    Sep 2010
    Ottawa
    142
    Russell fittings are very nice and pretty, but they must be making a fortune because they are overpriced IMO.
    Aug 2008
    Kamloops
    2,050
    i agree 100% russel is beautiful stuff but not worth the money at all. I have so much money in russel under the hood of my car I almost need a sponsorship from them
    GTRCer mitch32's Avatar
    May 2009
    Montreal, Canada
    728
    I would never trust Ebay lines. I run russell's, earl's, or Aeroquip everywhere (or stock). Ebay stuff is usually garbage unless its a name brand like russell's. I installed a ebay oil cooler (that came with lines) on a honda civic for a cheap buddy of mine and when I went to tighten it the fitting broke. Then I tried to change the fitting with Aeroquip ones, and the hose was so crappy that when I removed the old fitting the hose fell apart.
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    Quote Originally Posted by mitch32 View Post
    Lol.. Yep, sounds a LOT like my issue with my oil cooler! FML
    Avoid the cheap fittings/lines.. honestly it's not worth the hassle! You can build your own lines for ~20 dollars more, just shop around and do it right the first time
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Yep hit up MOPAC and alikes.
    name brand fittings can be had for decent prices and are worth it.
    GTRCer Ricky Ricer's Avatar
    Feb 2007
    Littleton, CO, USA
    264
    I bought these thinking I would use the line for the oil restrictor. I ended up not using these as the turbos have built in restrictors. I also ordered HEL braided lines and decided to not use them.
  1. WTB SS GTR Brake lines
    By SkyLizzle in forum Want to Buy
    Last Post: 05-24-2008, 03:33 PM
  2. WTB: Coolant Lines
    By black-typem in forum Sponsor Forums
    Last Post: 02-19-2008, 02:36 AM
  3. Vaccum lines
    By mightyrocker in forum GTS Tech
    Last Post: 01-26-2008, 02:56 AM
  4. Vacuum lines!!
    By BenC in forum GTS Tech
    Last Post: 07-08-2007, 10:12 PM
  5. WTB Braided Lines
    By MTL_GTS-t in forum Sponsor Forums
    Last Post: 07-05-2007, 12:02 PM
