Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Bolt on Options - Advice Needed
    GTRCer Imation's Avatar
    Nov 2007
    Halifax
    222
    Like most I'm on a power quest. Currently I have found my self at cross roads on what to do next.
    I have a couple ideas on my mind but dont know which to go with. I was looking at a few options. Bolt on, build the head, or a bit of both.
    Option 1: Bolt on
    Drop in cam.
    Tomei Pon Type B (260 duration 9.15mm lift ) or HKS 272 duration 8.7mm lift. At $800+ is either option worth the money or the gains? I have searched but no one is very clear on the topic.w
    Manifolds
    Tomei Expreme exhaust manifolds
    Greddy intake plenum.
    Again are these necessary to upgrade to reach 500-550whp
    Greddy or HKS hard pipe kits
    Option 2 Build the head
    Go with larger cams such as a tomei pro cam or hks step 2 with more lift.
    tomei valve springs and lifters
    mild port and polish
    Current Setup:
    RB26. Aftermarket forged bottom end, arp head studs, metal headgasket, and nismo oil pump.
    Stock head
    650cc injectors, nismo fpr
    STOCK Fuel pump will be replace with either one or two walbro 255
    Turbos- gt2860r-5
    full 3" exhaust and
    trust intercooler
    apexi suction kit w 300zx maf's
    Currently using nistune, greddy profec B, and aem uego for tuning.
    Apr 2008
    canada
    1,810
    don't bother with exhaust manifolds... for the money and the installation work you can get a lot more else where.
    if your bottom end can take it (which a forged bottom end should be able to), i would go with your option 2...
    lemme put it this way.... the head is the thing that MAKES power... and the bottom end (block and pistons) TAKE that power... so ur limiting factor here is not what power you can "take" - its the head....
    so yah, a pair of cams, adjustable cam gears (to help dial in the power band), a mild port and polish, and crank up the boost .
    in all honesty though if your goal is around 500 whp, you can get there by just turning up ur boost to like 1.8 bar... the stock head is fairly good up to about that level.
    Nov 2007
    Halifax
    222
    Ok so it seem like building a head is the way to go.
    What size cams can you put in before you get a lumpy idle.
    I drive the car a fair amount and don't want to give up practicality
    GTRCer derk's Avatar
    Dec 2005
    Coquitlam, BC
    1,476
    you dont want too much duration if its gonna be a relatively stock car on the stock redline, high duration cams will move your powerband higher up the rpm range. for a street car, you want short duration, and big lift, otherwise it'll feel really laggy, and make the powerband rather unpractical for the street.
    but you cant really fit anything bigger than poncams without machining the head to clear bigger cams, so poncams are probably the way to go. together with a mild port and polish, meth, and turn up the boost along with the generic boltons like turbo outlets/downpipe/exhaust/intake, and a good tune, should make for a really streetable gtr with a fat powerband
    Dec 2007
    Quebec
    3,209
    Quote Originally Posted by derk View Post
    Now I get it!!
    OEM is 248 btw! they make 252 but I guess it's stupid to change them for only 4 degrees.
    Apr 2008
    canada
    1,810
    i've heard a lot of good things from people running 264's or 272's and usually the lift we see with those is like 9.x mm lift or 10.2
    Nov 2007
    Halifax
    222
    So how much lift can you run without machining the head to clear the lobes? I was looking at the pro cams with 10.25 and 270degree duration. Too much or should I go with the 260degree
    Also the stock cam duration is only 240 degrees?
    Dec 2007
    Quebec
    3,209
    248 I said.
    Dec 2005
    Coquitlam, BC
    1,476
    i dont know the exact mm of lift, but pretty much any average cam that is in the 10's will require machining
    tomei makes a sweet 260deg 10.8mm cam that i want to try out
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    Tomei's are nice till you have to use their $400+ buckets for their large cams. Bigger cams = laggier.
    People out there can make over 500whp on a stock head and GT2530s.
    Also, for the thread creator, these cars have been around over 20 years, they have been modded in soooo many ways it sick. You asked a noob question there. Check out some builds all over the world. Someone out there has done it.
    On that note, you should try twin T04Z SPL turbos.
    lol
  1. engine build advice and oil cooler info needed
    By andy89 in forum GT-R Tech
    Last Post: 10-24-2010, 05:47 PM
  2. help/advice needed big time
    By Matty in forum GT-R Tech
    Last Post: 05-25-2008, 11:55 PM
  3. Need to call Japan from T.O.- Advice needed
    By gtrtt in forum General Skyline Discussion
    Last Post: 03-20-2008, 05:24 PM
  4. Clutch Fork Pivot Bolt Needed Asap
    By eastbeargts in forum Want to Buy
    Last Post: 03-01-2008, 11:56 AM
  5. Purchased R32 N1 from Japan...advice needed
    By jimbojones in forum GT-R Discussion
    Last Post: 03-31-2007, 01:51 AM
