Hey everyone im looking into buying a r32 GTR from a friend of a friend and he swears buy this car and everything he has done to it but yet he is selling it and i cant really figure out why he is if it is as good as he says it is ... So with that being said i have a list of mods that i have written out from what he told me and please dont mind the spelling as i am not the greatest lol and i am also just learning about the RB and its all happening so fast so what better then to ask awesome people who know all about it. heres just the mods he has done to the inside.
Mods:
Knife edged crank
Jun crank collar
N1 oil pump
N1 water pump
Hks adjustable anodized pulleys
Kevlar timing belt
Jun ,clear timing belt cover
87 mm wiesco pistons
eagle rods balance to point 001
Rc 750 injectors
Airo motive 1000 fpr
Custom high flow fuel rail
Jun step two valve springs
Jun step two retainers
Jun incolle exhaust and intake valves
Jun 280 10.5 lift cams
Squish pads removed
Ported intake runners
Ported exhaust runners
Combustion bowls ported embolished
Bench flowed head
Tapped intake manifold
Hks ssq blow off valve
Custom intake piping
Custom down pipe
Ported cast iron manifolds
228 60 rs turbos
Hks induction kit
Duel flexalite fans
Coil high flow rad
Nismo thermostat
Inovate wide band
Hks turbo timer
Evc 4 boost controller
Custom grounding kit
All erls bradded fuel and return lines and water channel lines
Flux capacitor
Cooling channel
Compression bumped down
Rain lans are staggered
Manifold tapped
Tailer battery relocation kit
Half size race battery
Walbroy intake pump
Hks 3 inch exhaust
Tomei dump pipes with heat wrap
Custom o2 bungs
Apexi power fc jetro
Tomei oil pan baffle
Tranny tran sfer case
Nismo 1.5 LSD
2x 3 bar map sensor tapped in to manifold
Corrio radiator
Carbon inlay cooling ducts
Engine block is borred to over 87 mm
Full tomei gasket kit
Alc race barrings
Alc head studs
Ati 1000 torque dampener (harmonic balencer)
Engine balanced to transmission
Os geiken twin plate and lightened fly wheel
And a new tps
Hks exhaust test pipe
Tein street coil overs
All vibrant clamps and hoses
Nismo motor mounts
Engine has a 9k
Car has 130k
What's wrong with it -
Power steering hard line is cracked
Replace AN fitting
Brake hard line leaking easy fix
Piping for turbos were not flowed
LinkBack URL
About LinkBacks
