So ive been looking around for awhile and cant seem to find someone who sells twin top mount manifold for th rb26. if anyone knows a site or a company who sells them P.M me thanks
Most are custom. The ones I've seen ran over $2500. You're better off low mount twins or single top mount. Unless you're running bigger than -10 turbos.
hks makes a set but its big dollars. wat size turbos are you running? dont quote me ... but i believe if u decide on low mounts and wanna push some big power. I believe a set of 3071r's can be done you just need to get some housings. Basically, you're looking at a high flow 2871r. A high flow turbo is considered to have bigger wheels. I still have to check a few measurements as I am looking to run a set of hybrid low mounts just because i have a ton of aftermarket parts on turbo side of my motor. (everything has been replaced) I believe the twOOgle car runs hybrid low mount turbos (its a 9sec car). hks gtrs turbine with hks 3040 compressor. I run a hybrid turbo on one of my cars just because its looks like a stock setup and when I already have an upgraded manifold and exhaust system that works, it was a no-brainer.
PM Super_Dude I know he has a nice setup that i m sure he would part with.
Twin top mounts is super baller in my book!
03 lancer DD
68 gmc w/355 cid rice killer
R33 GTR. The time is near!!
Only noticeable advantage of the top mount over bottom mount is the top mount setup makes it a lot easier to switch the turbos..
10 Infiniti FX35
09 Infiniti G37X coupe
02 Subaru WRX....sold
01 VW jetta 1.8T....sold
90-00-08 BNR32
92 NX2000...sold
95 S14 LE...Sold
Get a real cheap set of E-bay twin turbo exhaust manifolds and turn them other side up? The one problem I can think of is that the turbos would offset more to the front of the car then to the real in as in the OEM direction.
I was thinking of doing this over the winter. Could it work with stock turbos? I like the thought of seeing them instead of being hidden. I know intercooler piping would need to be custom but what else would need to be done?
Anyone have pics of their top mount set up?
I was looking at this. Pretty pricey but not as bad as other guys.
http://rawbrokerage.com/product.sc?c...&productId=174
hey making a deal with Super_dude for his set up. thanks for the info
