Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: wiring subs
    GTRCer skyrider32's Avatar
    Dec 2008
    Edmonton
    46
    wiring subs
    im sure many have done this just wondering if anyone can give me an idea on where they grounded there amp mine in the back bolted to the metal plate behind the seat and im currently grounded to the struit tower and not bass is coming. i have power to the amp just no bass i dont know if its somthing else im doing wrong or what but ideas on where to put the ground or if thats fine would be helpful thanks
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,501
    it needs to be to a bare metal surface
    GTRCer Nexsys's Avatar
    Jun 2010
    Hamilton, ON
    395
    i grounded mine at the bolt to the right of my trunk, holds the container of fluid, pretty sure its the attessa fluid jug, not sure.
    GTRCer future_R34's Avatar
    Jan 2009
    Appleton, NL
    151
    If you ground is no good your amp shouldnt power up.
    If it's powering up, check your RCA singal cables
    Dec 2008
    Edmonton
    46
    Quote Originally Posted by future_R34 View Post
    i had this problem with my friends truckthe amp lit up but subs wouldnt go moved the ground and it fixed dunno why. i check them at the head unit and there pluged in the right spots and everything ima try making sure there in the right colours not sure if that makes a difference
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    246
    No colors don't matter as long as both are hooked up to the deck of course. If your amp is powered up you should be fine. A bad ground can make you blow alot of fuses on your amp (assuming your amp has fuses most do in my experience) I know I hooked up a terrible ground and it worked but every two pounds the fuse popped I would check your deck settings I know every one I have had you can turn the preouts (rca's) on and off and up and down and check the gain on your amp could be turned right down?
    Jan 2009
    Appleton, NL
    151
    Oh yah, is the 12volt signal ( blue wire from your deck) supplying the power to turn on the amp?
    Dec 2008
    Edmonton
    46
    yea its hooked up because the amp only turns on when the sterio is on. ima try putting the subs in my friends supra and see if they even work cuz im at a loss. does anyone run a second battery or capacitor or anything like that i was told its a good idea as the gtrs alternator is of the smaller variety
    GTRCer evolution23's Avatar
    Mar 2011
    Surrey
    227
    If the light on the Amp is Green then ground and power are good. If the light is red or not on then there is a groun/power issue. Red (amp guard) usually means ground issue, no light means power. Your remote wire should be connected to the ignition wire on the decks harness (blue wire, sometimes has a white strip) if you have no blue wire on the wiring harnes, splice into the red wire on the harness for your remote wire. Make sure your amp filters are set correct, fuses arent blown, RCA are connected to Sub-out on deck and red to red, white to white. As for the ground, What usually works great is drill a small hole in the trunk off to the side (be sure to avoid anything underneath) then grind away the paint to expose bare metal, bolt it down. Also, kind of common sense but...make sure you have some speaker wire conecting the subs to the amp (seen this a few times...) And lastly, depending on if your deck has this feature or not, under settings see if you can turn subs on or off. If so, make sure they are turned on.
    Its always something simple that gets overlooked, let me know if any of the above helped.
    GTRCer Tony-R32's Avatar
    Sep 2010
    Winnipeg
    1,063
    Your issue isn't the ground although, scratching the paint off your ground point helps.
    Check your connections. Are your interior box wires rigged up properly? Is it a 4 ohm sub? I know for me I have a 4ohm sub running 2 ohms and a 2 channel amp, so both my sub and amp are bridged. Something like this could be your problem.
    Also i know with my amp, untill i turned the imput sensitivity up to full i was getting almost no response out of my sub. Try playing with the dials on your amp too.
  1. Alpine subs/box/amp/cap/speakers/speaker amp
    By gtrjerry73 in forum Off Topic Marketplace
    Last Post: 05-16-2011, 10:42 AM
  2. FS - Subs and amps
    By dah_hunter in forum Parts for Sale
    Last Post: 10-11-2007, 10:30 AM
  3. FS: Subs, Amp, Wires: $250
    By R32 Type-M in forum Parts for Sale
    Last Post: 09-29-2007, 04:05 AM
  4. FEELER: 2x AudioBahn 12'' Subs
    By SoupGTR in forum Parts for Sale
    Last Post: 08-19-2007, 05:10 PM
  5. Skyline stereos? Subs, DVDs, etc
    By gordonprice in forum Media
    Last Post: 01-02-2007, 02:30 AM
