Results 1 to 5 of 5
Thread: GTR hesitation/ almost stops itself
    GTRCer skyrider32's Avatar
    Dec 2008
    Edmonton
    46
    ok so a couple days ago i started noticing my idle drop when i was waiting at lights (from 1000 to about 500) and i kinda brushed it off till this weekend to have a look at what going on. now its at the point when when the engine gets warm it sometimes doesnt wanna start driving usually from 2nd to 3rd gear it stops moving and its almost like down shifting/poping the clutch but continues till rpm start to drop and car starts slowing down i havent done much to because unfotunatly my weekend got busy and so i havent tried changing the fuel filter (mostly because i dunno when it was done last and seemed like it couldnt hurt) and now i dunno what to do it almost seems like im not getting ignition or at least it feels like the car is starting to stall out as it slows down if anyone could let my know what going on or a bunch of things to try that would be great thanks
    GTRCer Bruizer's Avatar
    Oct 2006
    1,504
    Alternator would be a guess but a bad vacuum leak could do that too. Are your lights dining or gauges bouncing?
    No build thread.
    1991 nissan
    El terror
    Dec 2008
    Edmonton
    46
    that could make sense as i just hooked up subs in it ill unhooking them and see if that makes a difference since i dunno where to get a new altinator and need to be able to drive
    Oct 2006
    1,504
    Worse case, use you beater/daily driver.
    No build thread.
    1991 nissan
    El terror
    Dec 2008
    Edmonton
    46
    This is my daily driver my beater was stolen and I didn't wanna replace the steering column
  1. It Begins....and continues.....and stops
    By Wingnut in forum GT-R Project Cars
    Last Post: 04-27-2009, 11:21 PM
  2. 91gtr stops at 2500rpm!
    By 91blackgtr in forum GT-R Tech
    Last Post: 06-22-2008, 02:10 PM
  3. cutting bump stops
    By wingnutt in forum GTS Tech
    Last Post: 06-12-2008, 11:09 PM
  4. speedo stops at 20 kph and bogs
    By Matty in forum GT-R Tech
    Last Post: 04-19-2008, 04:18 PM
  5. Fuel just kinda....stops
    By chickey89 in forum GTS Tech
    Last Post: 03-27-2005, 12:16 AM
