Just bought one of these puppies for my r32 after I saw it in my friends g35. Very sleek and makes car feel just that much more updated lol. Will let you guys see the finishing results!!
http://www.auto-innovatio.com/magent...rt-button.html
$240??? RIP!
All it is, is a switch on the ignition line. Any switch will do. You can pickup similar one son ebay for WAY less. Example:
http://cgi.ebay.ca/Chrome-Engine-Sta...item19bfc2dba3
hmmm the 240$ one is a hell of alot better than that ebay garbage. The ebay one you still gotta use your key and either use your cig lighter hole or drill a big nasty hole somewhere, then its still only start and stop.
The 240$ one has alot more features and acts more like the start buttons in newer cars, no keys needed at all, the button does everything.
The thing im curious about is does it have its own FOB so it knows when YOU are in the car and not a theif? It says it ties into factory keyless systems and uses the factory FOB... r32's didnt have that. I have a 2 way compustar alarm and I wonder if this button would tie in with my aftermarket key FOB.
the install guide for the 240$ shows you have to cut a key !?!?! wtf...
http://www.auto-innovatio.com/magent...ng_diagram.jpg
LOOOOOOOOOOOOOOOOOOOOOOOOOOOL! Then what is the point of paying $240 to have something similar to the ebay one AND cutting a key?
I rather have the ebay one and put in/pull out the key each time. If it was a newer car, something with keyless entry and a FOB and yes sure, the $240 is a much better option.
coool feature! we all r entitled to our own ideas n tastes!
I think the op is just pulling our legs with this one, must be.
RB20DET[FTMFW]FOOLS//.
if this could be integrated to be used with my compustar 2way remote, then id rock one of these lol go get a cheap key cut, then cut the head off of it, put a cap over the ignition cylinder and your done, then atleast it would perform the same as any new car with push start
I'm not a cheap f#€*er so I'd probably go with style like he did. Cheap eBay crap isn't my thing, otherwise I'd be rolling ebay intercooler, rad, ecu, oil cooler, stereo; rims, so on. Maybe he can afford the luxury.
Do it!!!
No build thread.
1991 nissan
El terror
for the financially challenged
http://www.dealextreme.com/p/blue-in...g-dc-12v-24561
you wouldnt be cheaping out, youd just be smart.
all it is is a by pass switch, go to any electronics store and get a button for 50cents - 2 dollars its the same thing.
all you are paying for is instructions and the fact that it says "engine start" on it. and if thats what you want just do a Google search for a DIY and buy what Kenger posted.
or if you are to lazy to do that , spend a couple of 20's on one of these http://www.ignitedperformance.com/sh...&parent=6&pg=1
