Results 1 to 4 of 4
Thread: *looking for thread how to change tranny fluid*
    Jul 2011
    Toronto, ON
    2
    Hey fellas,
    Were is the best Place to read and follow simple directions in replacing tranny fluid?
    Thanks Mike
    Jul 2009
    Vancity, BC
    647
    if no hoist.
    use jack stand and level car
    remove filler plug first
    remove drian plug and drain fluid
    put back drain plug on nice and tight not too tight its tapered anyway
    then put 4.1 or so liters of mtf whatever you have using a fluid transfer hand pump
    let the fluid spill out of the filler hole then put the plug bakc on
    done
    my drian plug was seized to ****...so i had to suck out the fluid from the filler hole...lol
    good luck
    btw i used 2 bottles of redline mt90 and 2 bottles redline mtl...good enough
    Jul 2009
    Vancity, BC
    647
    GTRCer albertm7's Avatar
    Jun 2010
    Calgary
    76
    If you don't have a pump, you can gravity feed it from inside the car
    Just take out the panel surrounding the shifter and feed the hose to a person underneath the car who will then insert it into the filler plug
    The drain & filler plug are 1/2" drives
    Like markc32 said, loosen the filler plug first before the drain plug or it will get seized
    I tighten the drain plug until it is almost flush with the tranny
    gl hf
  1. full fluid change
    By DF(G)TR in forum GT-R Tech
    Last Post: 03-13-2008, 06:45 PM
  2. Tranny/Diff fluid?
    By RedlineGTR in forum GT-R Discussion
    Last Post: 06-09-2007, 04:20 AM
  3. Tranny oil change
    By dl337j00 in forum GTS Tech
    Last Post: 09-05-2006, 11:04 PM
  4. Transmission fluid change, what a difference
    By Kaane in forum GT-R Tech
    Last Post: 03-17-2006, 12:24 AM
  5. How many litres of Tranny fluid?
    By pumped in forum GTS Tech
    Last Post: 11-17-2005, 06:34 PM
