have a boost leak havent been able to locate it anyone have easy ways to find it? and where is a likely source?
Wanna give a bit more info on what you mean by boost leak?
Do you have a compressor and a tester to fit over your intercooler piping? Get some soapy water in a spray bottle and squirt it on all your couplers, that should make them alot easier to track down. Make sure you have a way to safely control the pressure depending on how big the compressor is!
could be anything.....cracked vacuum line, loose coupler, leaky bovs..... best way to find out is pressurize the system and spray possibly areas with soapy water (air leaking will cause bubbles) like silbee said. check the tech section...been cover a million times
They are few inovators, but many followers....
