Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Thoughts on these Headlights
    GTRCer v8-killer's Avatar
    Mar 2011
    coquitlam, BC
    74
    did this to my headlights the other day and id just like to get peoples opinions
    Dragon Humper's Avatar
    Mar 2007
    Kamloops BC
    1,551
    Nice, they look like Bimmer lights. Gives them that N1 look.
    Rides:
    2011 Silverado Crew tow rig.
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    836
    I think that looks great ! Especially with the tinted corner lights.
    Because you painted the "cone" around the projector did you a lot of brightness from the headlight ?
    GTRCer flipridah17's Avatar
    Jan 2007
    Vancouver, BC
    2,171
    looks good! Which paint did you use?
    Mar 2011
    coquitlam, BC
    74
    Quote Originally Posted by evilgtr View Post
    thanks.
    hmmmm no not really... the brightness is still same to me lol
    thats how it look at night time just with the halo lights.
    Mar 2011
    coquitlam, BC
    74
    flipridah17 : Flat Black with 300ZX halo rings
    Jan 2010
    Manitoba
    216
    Nice work! I did the same thing with mine, only I wrapped the the fog light lenses with tape and stuck them back in before painting. Oh, and no halos..
    Haven't put the covers on in the pic's, I'm reworking the cut-off gates to correct the beam.
    Quote Originally Posted by Snow View Post
    Sure a condom holds water but you don't see me drinking from one.
    Dec 2008
    GTA
    438
    Looks clean
    Did that to my ek civic, looks awesome
    No need on the 33, sexy black from the factory
    doc
    doc is offline
    GTRCer doc's Avatar
    Apr 2010
    Mississauga, Ontario, Canada
    330
    how to coming soon?
    or you providing services?
    Jan 2010
    Manitoba
    216
    "How to"
    Tools and materials:
    Phillips screw driver
    Flat screwdriver
    Painters tape
    Sand paper (I used 220 grit)
    Oven
    Gloves
    Spray paint
    The task:
    Remove light assemblies from car. Place lights (one at a time) in oven for 5 min. at 350, Using oven or welders gloves remove and gently pull the cover from housing being careful not to get the sealant all on yourself or in side housing. You may need to us the flat screw driver to start releasing the cover, but be gentle as the house will be softened from the heat.
    Next, remove the two screws attaching the frame at top of housing. Start at one end and get your fingers under the frame and pop it off its clips. Be sure to do this sitting down with the housing on your lap, you don't wanna drop it. On the back of the frame locate and straighten the tabs holding the cone for the projector in place and slide it out, again be gentle with these as the tabs may break off.
    Paint and chrome generally don't bond to well so grab your sand paper and remove the chrome from the frame, if you want to keep the fogs reflective only sand 5-10mm into the bucket. Now give'em a good wash in soap and water!
    To paint the frame and keep the fog bucket chrome I wrapped the lenses with the tape and popped them back into place. Wrap the sides first with about 1cm of tape hanging past the inside edge toward the clips and work the extra tape over the lense face. Cover the lense face and trim flush around the edge, to much tape and it won't fit clean and paint may run into the bucket.
    Spay them! follow the directions on the can and don't rush, runs suck, lol. Throw down a few coats and give them 24 hours to cure. Reverse the dis-assembly procedure and enjoy. Reheating the covers and housings will help urathane seal better. If one wanted, the old sealant can be removed and new urathane could be applied at a glass shop (Apple/Speedy) or can be purchased at an autobody supplier.
    I'll add a post on how I'm correcting the beam cut-off, with pic's, when I get off my lazy butt and finish the job.
  1. Thoughts on this car
    By BKC in forum GT-R Discussion
    Last Post: 08-29-2011, 11:08 AM
  2. Possible new car! Thoughts?
    By Dylan19 in forum General Skyline Discussion
    Last Post: 07-03-2011, 06:14 PM
  3. Dec 21 2012 your thoughts!
    By GTR-guy in forum GTRC OT Pit
    Last Post: 07-18-2008, 02:13 AM
  4. Thoughts on this GTR
    By hamiltonr32 in forum GT-R Discussion
    Last Post: 10-31-2007, 10:36 AM
  5. Rims!? Your thoughts...
    By Paradis in forum GTS Discussion
    Last Post: 04-28-2006, 11:30 PM
