anyone running without catalyctic converter? the reason im asking is i supect mine might be clogged and instead of putting another one i want to just put a straight pipe instead now will this affect the performance of the vehicle?
1987 Nissan 200ZR
RB26DETT
Apexi Power FC
HKS Intake
Kakimoto Muffler 3" Pipe
After Market Coil Packs (RED)
1991 Nissan Skyline
RB20
Upgraded Turbo
14 PSI Boost
there are lots of people running without cats. test pipe = more flow...
test pipe? same as straight pipe?
1987 Nissan 200ZR
RB26DETT
Apexi Power FC
HKS Intake
1991 Nissan Skyline
RB20
Upgraded Turbo
14 PSI Boost
so if cat are clogged will this coz stalling and rough idle?
1987 Nissan 200ZR
RB26DETT
Apexi Power FC
HKS Intake
1991 Nissan Skyline
RB20
Upgraded Turbo
14 PSI Boost
Only way to find out is to run it from the open downpipe.
I'm running a "highflow cat", per se, without issues. Cut the sensor off since it was rotten in the original (a real high flow) cat. Matched with my kakimoto it sounds boss; the same isn't necessarily true for exhausts that have a high pitch though.
A clogged cat will make the car feel like the handbrake is on when you're driving. Best way to test is to just undo the exhaust and see if it makes a difference.
You don't get higher flow from a test pipe vs a good cat, just more noise, environment destruction and the chance to get a 1000$ fine.
EDIT: And yes a test pipe is just a straight pipe that replaces the cat.
Yes a test pipe is a straight pipe. All it is is a section of exhaust pipe the same diameter and length of your cat with identical flanges on either side and sometimes has a few bungs welded in for A/F gauge,EGT sensor.. It's a hollow pipe.
You will notice the power and it will me much louder like Caporal mentioned. If it's to loud for you add a resonator downstream of the test Pipe or buy a silencer for your muffler thats all I did. Except I love the sound of my car so much I havnt even taken the silencer insert out of the plastic hahaha it's loud !
so took the cat off today, sure feel the difference it breath a lot better now will see if it will still stall (cat is clogged tho) idle seems to be smooth now.
1987 Nissan 200ZR
RB26DETT
Apexi Power FC
HKS Intake
1991 Nissan Skyline
RB20
Upgraded Turbo
14 PSI Boost
There are different techniques that people use to clean cat's but I have never tried it. Do some searching you may be able to Restore it and put it back in you want.
How does it sound ? Haha I love mine
