will these fit on a r32 gtr . work meister s1's 18x8.5 +24 18x10 +20
yes however you will need to roll your fenders
For GTR's you cannot run different size wheels only offset
no!!!!!
I heard if It will F*CK your transfer box, unless you find tires that keep the same rolling radius all the way around..It's the diameter that matters. Even if the tires are the same size you can double check with string or measuring tape that the circumference of each tire is the same. There have been know cases where even the same brand, model and size of tire yet different manufacturer dates have had significant differences in circumference .don't trust what's written on the tire, measure it yourself
The fronts will fit well, I am +18 on a 9" rim and they are just flush with the fender. The rears will also be right flush with the fender and will need a roll at min. and a slight tire stretch.
And don't listen to anyone that tells you running staggard tires/wheels is a no-no on a GTR, been doing it for over a year now and narry an issue to be had. The only thing you MUST do is make sure that the rear tires are TALLER than the fronts (or the same). If the rears are shorter than the computer will think that you are having wheel spin and will start to enguage the AWD all the time (wearing out your transfer case clutches).
17x9 +18 on the front and 17x10 +37 on the rear with 245s and 275s, both a perfect 24.7" tall. The AWD acts just like stock.
Rides:
2011 Silverado Crew tow rig.
Yer what would the factory Nissan GTR Manuel know about what size wheels and tyres to run,
If I was you stick to the same size all round. Any way y not put 9 or 10 all round, that's y the GTR has the pump gards.
Yer? Yar? What, are you a pirate in your spare time?
It's a non-issue, staggared is fine if you follow those rules I laid out. Been thumbing my nose at what the factory recommends for 20 years and am much further ahead for it. You should try it some time.
Rides:
