Results 1 to 8 of 8
Thread: Having some issues
    Nov 2011
    Ajax, ON
    10
    Having some issues
    Alright i took the car out a week ago and was pushing it pretty hard. Between 5k rpm and 6k it jerked a bit and took like 10 seconds to actually get to 6k rpm from 5. so obv i stopped hammering it. Then the car just dies coming up to a corner. I started it back up and drove 2 blocks to get home. I just bought this car so i decided to do an oil change. After i did the oil change it fired up no problem. An hour after though it won't start. turn's over and everything i'd assume it's lacking ignition or fuel. What changed within that hour?If any of you have had similiar experiences please share. Note: the plugs are brand new.
    Thanks, Lance
    GTRCer nimblestix's Avatar
    Mar 2007
    Maple Ridge
    498
    Fuel pump?
    Sent from android using Tapatalk
    Dec 2008
    GTA
    438
    Being an old car, the electrical/ignition usually needs an update
    Wiring the fuel pump directly to the battery will get a better contact
    And a new fuel pump is no more than $150 and beneficial. Could be the issue if the car will turn over and run and then all of a sudden not start. Lack of fuel, I've had similar symptoms pre upgraded fuel set up
    R33 GTST RB25DET series 1
    Nov 2011
    Ajax, ON
    10
    What brand of fuel pump are you using?
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,891
    doesnt sound like fuel pump to me. if the fuel pump was faulty it most likely wouldnt start at all. if anything is wrong with the fuel pump its dropping off voltage causing it to die after its running. This doesnt mean the pump itself is bad but rather your wiring. Do a 12v conversion to your pump (google it) and see if it helps. for the $150 hes suggesting prob just buy a walbro 255lph or a oem replacement.
    Nov 2011
    Ajax, ON
    10
    It isn't starting at all.
    GTRCer speedfreak's Avatar
    Feb 2006
    Toronto
    374
    Test for spark , fuel pressure first.
    Basics
    Favorites
    lucky_cefiro
    you\'re not listening
    entelijint
    stop saying "yall"... i'm picturing you with a mullet.
    mullet+skyline=*shiver* i dont even want to think about it
    Quote Originally Posted by specialedition View Post
    He ended up popping a tired and he failed at life.
    Sep 2010
    vancouver
    1,891
    Quote Originally Posted by 91SkylineGTR View Post
    o well then of course. check for fuel and spark. simple mechanical basics. to check for fuel you can simply pull a spark plug and smell it. or you can pull the feed line off of your fuel rail and prime the car see if fuel sprays. to check for spark pull a coil pack stick a spark plug in it and hold it close to ground crank it and see if it sparks.
  1. HELP!!! 4WD issues
    By Collector1313 in forum General Skyline Tech
    Last Post: 04-14-2011, 08:46 PM
  2. a few issues with my GTR. help please
    By benk23 in forum GT-R Tech
    Last Post: 11-20-2007, 03:08 PM
  3. Replies: 7
    Last Post: 12-19-2006, 08:31 PM
  4. More issues!
    By hamiltonr32 in forum GT-R Tech
    Last Post: 08-06-2006, 01:25 AM
  5. New car and issues already
    By Mac71 in forum GT-R Tech
    Last Post: 05-26-2006, 01:36 AM
