Results 1 to 9 of 9
Thread: Battery
    Aug 2009
    Calgary, Alberta
    49
    Battery
    Hey what battery does everyone run in there GTR??? And on a side note where the >!@>#!@# is the belt tensioner???
    GTRCer rolyaT's Avatar
    Sep 2010
    edmonton
    196
    Depends if it relocated or not, I use a red top on my car. Belt tensioner is straight down from you cams behind the belt cover
    Aug 2009
    Calgary, Alberta
    49
    Yeah i want to keep it in the stock location. With the red top you had to change the ends on the wire to some bigger ones correct? Reason im asking is i have my battery from Japan in there and its DOA, and then my belts are super tight so i gotta loosen it off a tad
    Jul 2009
    Vancity, BC
    647
    i used an ek civic sized battery same size as the jdm one lol
    which belt tensioner? timing belt? or drive belt tensioner?
    Aug 2009
    Calgary, Alberta
    49
    Would be drive belt
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,044
    You can use an MT51 size, I forget if it's regular or reversed terminals though.
    RightDrive Inc. Parts Manager
    10% off HKS Air Filters!
    Mar 2008
    toronto/collingwood
    169
    Quote Originally Posted by Daryl @ RightDrive View Post
    its reversed terminals i found this out the hard way when i tried to toss an optima red top in there, it will fit but you gotta fiddle with the wires to get some slack.
    SLIGHT THREAD HIJACK!!!!
    anyone used a braile or similar tiny racing battery?
    does it put stress on the alternator because its constantly trying to charge?
    Aug 2009
    Calgary, Alberta
    49
    You can get the MT51 with reversed terminals. The Mega Tron 51 or the Mega Tron 51R
    Jul 2009
    Vancity, BC
    647
    Quote Originally Posted by wannabe_sky View Post
    Would be drive belt
    theres two tensioner for ur drive belts....one would be th alternator itself and one between the a/c comp and crank pulley...that one is the same as the 300zx and just swap in a washer behind the rb26 tensioner and ur good to go in case u need to replace it
    part number for that is 11925-42L06 ac tensioner...i replaced mine coz it was chirping
  1. Battery?
    By krystalized_jdm in forum GTS Tech
    Last Post: 04-03-2011, 06:26 AM
  2. Need new battery
    By G.T.R in forum GTS Tech
    Last Post: 10-17-2007, 04:08 PM
  3. Battery Help
    By Nyhkon in forum GT-R Tech
    Last Post: 03-31-2007, 05:45 PM
  4. Battery
    By Fredywise in forum GTS Tech
    Last Post: 07-12-2006, 05:31 PM
  5. battery?
    By thumper in forum GTS Tech
    Last Post: 10-19-2004, 05:07 AM
