Originally Posted by
GTR-Dad
Nice car! I love the stock look. Especially when it handles better than anything else on the road!
Ensuring reliable oil supply is your main concern.
1 - Find out if the oil pump drive design error was fixed for this car. If not, read the RB26 oil drive issue that's stickied on this board somewhere.
2 - RB26s have been known to suck air into their oil pump intake, particularly under high load, high lateral g conditions. This is the quickest way to a rebuild. Fixes range from installing a swinging oil pickup, to installing a sump baffle, to installing an oversized sump, to overfilling the sump. Be careful with this last one as you don't want your crank splashing in the sump. (I don't know what the safe overfill limit is...)
If you run power to the OEM injector limits you'll also be approaching the clutch limits. Avoid generating any heat with it and it'll have a better chance of hanging in there than if you do even a moderate launch.
Many with RB26 experience will suggest you should budget for a rebuild with 115k+ on the clock. I've heard from Skylines Australia guys that RB26 reliability beyond 120k depends very strongly on maintenance from day 1.
Stay off the rev limiter, don't get too greedy with the boost (both magnitude and duration - 15 seconds on boost is a limit one SAU guy who had 210k+ on his RB26 recommended), and focus on efficiency mods rather than just turning up the boost.
Enjoy the car!
Dan
