Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: 1990 Veilside Evolution Skyline GT-R - 502whp
    Nov 2006
    72
    SOLD - 1990 Veilside Evolution Skyline GT-R - 502whp
    Hi guys,
    Here is our (our as in me and my spouse, we are co-owners) project car. This is a special edition GT-R tuned by Veilside at their garage. Most of the work you see was done by them. After the car landed, we fixed a few things and we made sure that everything was A-1 before we do any serious driving. After almost 1 year of babysitting this GT-R and making sure everything is solid, we took it to a dyno. The result is 502whp @ 8000 rpm on 16psi of boost. All this on pump gas of course.
    Modifications
    Engine
    2x Top mounted IHI RX5 turbos
    2x External HKS S/S Racing wastegates
    HKS Race Cams (IN66° lift 9.5 EX68° lift 9.5)
    HKS adjustable Cam gears
    N1 pistons
    N1 pumps
    Bosch 660cc injectors
    Splitfire Coils pack
    Metal head gasket
    NISMO fuel pressure regulator
    HKS oil filter relocation kit
    HKS GT intercooler
    HKS blow off valve
    Twin-plate OS Giken clutch
    Fujitsubo Super Legalis R Stainless Steel exhaust
    Polished intake manifold
    Cusco aluminum catch-can
    Electronics
    GReddy boost meter
    HKS turbo timer
    HKS electronic boost controller
    HKS VPC
    Omori gauges (exhaust temp - water temperature - oil temperature - oil pressure)
    Innovate Wideband O2 Sensor
    NISMO 260km/h cluster
    Almasi Tuned ECU [Replacing HKS PFC F-CON]
    Handling
    Gab suspension
    Cusco strut tower brace
    Sway bars
    Full Roll Cage
    Desmond Regamaster wheels
    Dyno sheets
    Note: Numbers done on a Dynapack in rear wheel drive mode on a hot, humid day
    Flywheel HP vs Flywheel TQ (computed using a 1.18 ratio)
    Wheel HP vs Boost (PSI)
    AFR vs Wheel HP (AFR is off. 12.5 is actually 11.8, so the entire scale needs to be lowered by 0.7)
    Pictures (Not so great, will work on that!)
    Front
    Side, displaying Veilside original graphics
    Engine Bay
    Top mounted turbos
    1990 Veilside Edition Skyline GT-R
    GTRCer Brewpubeaver's Avatar
    Aug 2007
    Portland OR
    160
    was this on an engine dyno? other wise most roller dyno`s say it is flywheel, but there really isnt a full proove way to determine critical drive train loss...
    do you have any pictures of the car>? seems like a beauty
    Nov 2006
    72
    This was done on a dynapack, flywheel power was calculated with a ratio of 1.18. Real number was 502whp. I'll add some pictures of the car a bit later. We are also shooting a TV show next Monday (should be aired sometime this Fall), so there will be, eventually, a possibility to see the car in action.
    GTRCer The Stig's Avatar
    Jan 2004
    Vancouver
    725
    Very nice! How are those RX5s in terms of reaching full boost? And post some pics of the car itself when you get the chance.
    2012 Deep Pearl Blue Black Edition GT-R
    Some say my teeth glow in the dark...
    And that if you tune your radio to 88.4 FM you can actually hear my thoughts...
    All we know is, I'm called The Stig
    GTRCer felix yuen's Avatar
    Dec 2005
    vancouver bc
    1,590
    damn..
    Honda tuning is a LifeStyle
    Nissan tuning is to go stupid FAST !
    Goals for 2012
    Get the dAmn thing rUnning
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,044
    any pics of this beast?
    RightDrive Inc. Parts Manager
    10% off HKS Air Filters!
    Nov 2006
    72
    Added remaining dyno sheets, and re-formated the main post. Pictures of the car will be posted soon. Sorry, I'm just too busy with work and stuff.... :x
    Edit: Anyone can tell me why the dyno images are not being displayed? I can only see the link, but can' embed the image inside the post...
    GTRC Guru
    Feb 2007
    Torrance, CA
    251
    Nice....I remember the RX-5's from way back in the day. FYI, they are essentially IHI VF23s. If that dyno's AFRs are reading correctly, that is one LEAN machine. I recommend you have it retuned if you want that engine to stay together.
    Eric Hsu
    motoIQ.com
    May 2006
    237
    Is it lean up to 3000 rpms and then acceptable after that?
    It appears to be a couple of points below stoichiometric after it hits 3300 rpms. Or should they be targeting closer to the low 11's for AFR?
    Thank you for the tutorial.
    Cheers!
    Nov 2006
    72
    Thanks for your observations Xsdailo. I'm having issues finding good documentation on these turbos. I'll look for this new name VF23.
    As for the AFR, when we did tune the engine, we were aware that the O2 sensor was reading leaner than what it should be. I don't have exact numbers on the actual difference, but I'll ask. It was done using an Innovate probe (which is essentially a Bosch one).
    If I can ask, what kind of AFR were you expecting? I'd like to get your opinion since I run a wideband in the car (different from the one that we used on the dyno) and I'll do a comparaison between the numbers I see on my gauge and what's on the dyno chart... If I can get the data logging working....
