Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: project R14
    GTRCer rbs14's Avatar
    Mar 2008
    montreal,quebec
    266
    project R14
    here is my project :
    chassis:
    - Tien super drift coilover
    - GReddy strut bars front and rear
    - Wheels Gullflame 18x8.5(fr)18x9.5(rr)
    - BFGoodrich g-Force T/A KDW 2
    - Suspension tech. sway bars fr and rr
    - Tien tension rod
    - Tien tie rod
    - z32 brake conversion (30mm)
    - Brembo slotted front and rear rotors
    - PROJECT MU B-Force z32 Front Brake Pads
    - PROJECT MU B-Force S13/S14 Rear Brake Pads
    - 5 lug conversion
    engine :rb26dett aka Godzilla
    - R-33 rb26dett
    - JE piston (87mm) stock rod and crankshaft(balance)
    - GReddy clear valve cover
    - GReddy cam gears
    - GReddy timing belt
    - GReddy Racing Ti-C Catback
    - GReddy intake plenum
    - GReddy ASP
    - GReddy ka24 rad
    - McKinney Motorsports RB26DETT Engine/Transmission Mount
    - TOMEI S14 SR20DET Upgrade Fuel Pump
    - SARD Adjustable Fuel Pressure Regulator
    - new timing belt tensioner and idler
    - nissan rebuild gasket kit
    - ARP head and main stud
    - N1 water pump and oil pump
    - Apexi power-FC et power-FC boost controler (pas encore commendé)
    - stock oil pan modifié
    - Nismo thermostat
    drivetrain:
    - rb25 trany
    - ORC twin plates clutch
    - McKinney Motorsports Custom Drive Shaft for S14 95- 98 240SX
    - Nismo slave cylinder
    - LSD tomei or kazz to come
    - GReddy diff cover
    Mar 2008
    montreal,quebec
    266
    i will post pics a soon as i can !!!
    Mar 2008
    montreal,quebec
    266
    here we go ..
    my car and some parts
    Mar 2008
    montreal,quebec
    266
    here are my new parts for now !!!
    Mar 2008
    montreal,quebec
    266
    just finish my battery relocation
    my front brake are done ...waiting for my back rotor to came back ...
    tires and mags :
    Mar 2008
    montreal,quebec
    266
    here is my car with my mags on .
    rear tire with out the roll .
    pics of my fenders geting rolled
    Mar 2008
    montreal,quebec
    266
    KA is out and preping for the RB
    with the motor mounts in
    Mar 2008
    montreal,quebec
    266
    just bought a intercooelr .... R32 GTR GReddy (TRUST) 4 layer R core
    650 $$$ compare to 2500 new .... good deal i think .
    engine pics :
    piston assembly :
    crank :
    hold pistons (86.5 N1 piston) for sale btw:
    hold bearings :
    and the block :
    Mar 2008
    montreal,quebec
    266
    my oil pan is cap and ready for my RB26rwd
    new Tomei gasket kit.
    here :
    Mar 2008
    montreal,quebec
    266
    ok got a super update ... i havent post here for a will ... here is the progress for now ....
    me working on the beast (puting my last piston in)
    final look at the bottom end
    put the head ont the block whit my tomei head gasket ... and started to putt back the intake side .
    the cams are on
    sorry for the poor pictures it with my cellphone
    and i want it to look a bit like that when it will be finish
