Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: swap r34 transmission into r32 gtr
    Sep 2008
    montreal
    4
    hey i just bought an r34 ge trag transmission with cluch, diff, drive shaft and transfer case i think its prety much all i need for mecanical side but im not sure what to do for the speedomeder cas the r32 is mecanical and the r34 is électronical so if anyone cxan help me let me know
    thanks nei
    l
    Banned
    Aug 2006
    5,913
    there are threads on the subject of putting the r34 v160 into a r32.
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    this has been done many times. I've heard pricing from 4k including tranny (bought for about $2500) and 10k to do this. I'd like to follow the same path as the R32 has a weak gearbox. This will be a nice project if you go through with it.
    Dec 2004
    Whitby
    6,071
    Pretty sure you need a transmission cross-member too.
    Race. Win. Live.
    GTRCer sr20-gt30r's Avatar
    Aug 2007
    Granby, Quebec
    296
    you need
    -tranny cross member(but you can shim the r32 one)
    -R34 shifter assy
    -the front piece of the propeller shaft or a complete r34 driveshaft
    -front drive shaft
    -R34 flywheel (not the same thickness than r32/r33)
    -pull type clutch(or a pull to push conversion kit)
    here's on post on gtr uk
    http://www.gtr.co.uk/forum/53355-r34-gearbox-r32.html
    90 "torque beast" BNR32 RB28DETT : HKS 2,8l stroker kit + twin GT2860-5 + nismo intake plenum + greddy 264 cams + 1000cc RC injectors + Apexi D-Jetro + Almasi tuning=
    632 WHP @ 21psi
    589 lb/ft of torque
    ¼miles : 9.74 @ 142mph
    GTRCer DeviantRebel442's Avatar
    Sep 2007
    Vancouver, BC
    1,831
    i will be doing this swap around January February before my car goes back on the road for the spring/summer prolly about 4-5 grand including labor from a friend
    Fraser Valley Imports.ca
    (The Detailer)
    We aren't just Importers, we are Owners
    Bike Project: Susie - 05 Suzuki GSXR 600
    Car Project: In The Making
    GTRCer GTRbrian's Avatar
    Oct 2006
    Toronto
    135
    i was gonna try the same swab but i got a new stock tranny instead. good luck eh, i didnt have the balls to figure that one out
    falcon's Avatar
    Jun 2007
    Van
    5,502
    what is the HP rating on the R34 transmission?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,700
    Not so much hp, more like torque that probably would damage the gearbox. From what I understand a dyno measures torque and converts to hp via a formula.
    Look at R.I.P.S Drag-R R34 GTR with torquey RB30 engine, as I think it's producing up to 1200hp with what seems to be the stock R34 GTR gearbox. Not sure if that car runs that much hp on the dragstrip -
    http://rips.drag-r.com/Build/build-index.htm
    It's driven aggressively for a 9.7 sec run -
    http://www.youtube.com/watch?v=fpBJCHNdEBA
    Could have gone quicker, as I think he backed off before the line due to powersteering belt failure and car headed towards centre line.
    It is said to weigh over 1700kg with full street trim.
    Jun 2004
    Windsor, Canada
    1,992
    FROM what I understand:
    The R32 speedo pickup will fit into the R34 transmission. So that solves your speedo issues. Just take the whole bit out of the tcase and put it in the R34 one, and hook your speedo cable up to that.
    the rest, I know nothing about.
    if I did this swap I'd just import a whole R34 GTR and swap everything. And part out whatever I don't use.
    1992 GTR
    1988 Mazda RX-7 10AE
    1999 F250 Superduty 7.3L Turbo (tow vehicle)
