Recently I picked up a basket case of an R32 GTR, started going through the car, currently have it stripped to a shell. I have a RB26DETT and all of the drivetrain. I had a replica LS1 V8 block for mock up from my last project and thought it might fit, since the LS1 is approx. 20" wide, 20" long and 21" tall (including intake manifold). The fit is quite easy and the engine is tiny when put up next to the RB26, and I'm sure it is also much lighter with the mass more centralized. Win win.
This swap has been done before but without keeping it awd, which is a must for my project. I have some concerns with the drivetrain being up to the task of handling the large displacement V8's FI torque, mostly the front diff and transmission(easy to upgrade). Since the car will be gutted, and 90% a road course track car, full cage, LHD converted, just enough equipment to keep it street legal (technically). It should be significantly lighter then stock which eases the loading on the drivetrain, it will also be driven properly and not driver abused or hardcore drag raced. The drivetrains seem to be fairly robust, from research they tend to hold up fairly well to abuse, aside from the transmission 3rd gear issue.
The car is in the process of having it's suspension completely gone through, all suspension arms redone with heim joints and polyurethane, with the rear subframe being solidly mounted and tied into the roll cage. It needs to be a roller to get it into the body shop to check for straightness before building the cage. Most of these arms are but custom fabricated and relocated and fully adjustable for length.
Car has a ton of work needed before I get to the drivetrain, but it's always good to plan ahead and try to find the issues.
I'll put up some pictures as I go, not much yet but I hope to have the rear subframe back in the car this weekend to check fit with the aluminum mounts this weekend. Clean up the aluminum hubs and install the polyurethane bushings and reassemble with park brake and bearings.
LinkBack URL
About LinkBacks
