Well after owning my GTR since May of 07 I think it’s about time I started a build thread. My GTR started out as a nice clean stock GTR with a few minor mods.
Starting point
HKS hipermax 2 coilovers (love these)
Kakimoto tuned ECU (no rev limit or speed cut, unknown mapping)
4” HKS super dragger exhaust
Turbo timer
Tein tension rods
Braided stainless rad hoses
Now for the first little while I owned the car, I told myself I would be keeping it stock. After all it seemed really fast then, and I was still getting used to it. Then I discovered Racing…
The goal
To build the ultimate time attack/circuit racing GTR while not spending more than is necessary to do so. This means using my head instead of my wallet. The emphasis on this project will be to “engineer” the car rather than just throw a bunch of high-end parts together and call it a racecar. Performance wise, the main concern will be handling and response as this will give the best results for my application. This car will not be street legal or well mannered. For the time being, the car will stay in a super street kind of trim, but eventually will venture into unlimited territory.
To start off, I left the engine pretty much stock and tried to focus on handling and reliability. I felt by being slightly underpowered it would improve my driving by forcing me to carry momentum through corners and find the right lines. It was also a lot easier to be aggressive.
Specs as of 08 and up until the last few weeks
In addition to starting point
3” test pipe
14psi on stock turbos
advanced ignition timing
HKS shroom intakes
13” 8 piston Ksport BBK w/ Hawk blue Race pads
KVR rear slotted rotors w/ Hawk HPS+
Braided stainless brake lines all around w/ wilwood 570 fluid
Gramlight 57 Optimise 17x9.5+12 in time attack colours
Toyo R888 255/40R17
Removed rear seats
4 point harness’
Splitfire coil packs
Ported stock manifolds
ACT 6 puck race clutch w/ extreme pressure plate
RG lightweight flywheel
Earls braided lines and fittings for turbos
Koyo rad
Now this setup did me quite well, but after running a lot of it for most of 08 it gave me an idea of where I wanted to go with the car. The first order of business was to get some adjustable suspension links and get a good race setup dialed in. Next I needed to address my high oil temps cutting my time on the track short. Also that pesky Hicas had to go, especially since both of my rear hicas ball joints were shot. A/C also gets the boot. The battery also needs to move to the trunk, an easy way to shift ~40lbs from the front of an already front heavy car.
So I bought:
AMS adjustable RUCAS
AMS adjustable FUCAS
AMS solid subframe bushings
No name oil cooler/relocation kit
B&M 11”X 11” Oil cooler
Small PS cooler (you’ll see why later)
Catch can
Apexi BOV
Bings Z32 toe arms
Currently on the agenda:
Install solid subframe bushings
Have solid diff mounts made and install
Custom hicas lock (will explain this later on)
Install BOV
Install catch can
Relocate battery
Align (new snap on alignment machine at work yeeee!)
Roll fenders (rubbed bad at Mosport on Moss corner)
So this is more or less where I am at right now. I’m kind of half way through the last group of things I mentioned, Just waiting on some parts and some fab work. Once I get some pics up of the progress you guys will get a better idea of whats going on and where I’m at. When I get a chance I will make a post about my plans/parts for the engine build but that part of this project wont be commencing for awhile. My next post should be chock full of pics and updates.
I would love to hear any comments, criticism, ideas that you guys may have. Stay tuned as this will be an ongoing build.
LinkBack URL
About LinkBacks
