Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: BNR320001551 Build
    GTRCer R32GT-R's Avatar
    Jan 2004
    West Kelowna
    841
    BNR32001551 Build
    http://www.youtube.com/watch?v=ta_MHAhSjlM
    I had an older build thread going but i left my Internet provider and i lost most of the pictures. So i am on to stage two, motor build. to look at the older thead, with no pics. WTB: Q45 Throttle Body
    Tuning:
    Apexi PFC
    Motec PLM
    FC Datalogit V2
    Spec List:
    BNR32-001551
    ATL 22 gallon Fuel Cell with two surge tanks
    Bosch 044 pumps * 2
    Canton 1 micron filters
    Earls Check Valves
    -8an * 2 Feed lines
    -8an Return
    Sard 800cc green top injectors
    Sard fuel rail
    Sard Type RJ Regulator
    Battery mounted in trunk - Custom box
    Re and Re rear sub frame powder coat black
    NEW wheel bearings rear
    Re and Re CV boot kits rear
    Nismo Long Studs F&R
    Energy Poly Bushings
    Removed Hicas,A/C, Park Brake
    Defi BF Guages, Tac,Pyro,Boost,Oil Press,Water,Oil Temp
    Apexi PFC,Controler, Boost Kit
    Z32 AFM's new
    Trust 600*300*115 IC
    Trust T618z
    Trust Front Pipe 2 pc
    Custom recirc BOV kit
    Trust Raidiator
    Trust Coolent expansion tank
    Trust Oil Catch
    Trust Hard Pipe kit
    Trust Oil Cooler Relocate thermo
    OS Giken Superloc Rear
    Cusco Tension Rods Front
    Cusco Front Upper Camber -5mm
    Cusco Front Sway Bar
    Cusco Rear Sway Bar
    Cusco Rear Upper link
    Cusco Rear Toe Bar
    Cusco Rear Strut Bar
    Nismo Front Strut Bar and Master cyl stopper
    JIC Magic FLT-A2 Coilover 10 kg F 8kg R
    Custom Ti Exaust 90mm
    Custom Test Pipe with WideBand
    Motec PLM
    F50 Big Brake Kit Front
    Nismo LM 17" Wheels
    Nismo Engine mounts
    Nismo Transmission mounts
    Tomei 280 deg 10.25mm ProCams
    Tomei Oil Pan
    Tomei Oil Pump
    Tomei Bronze valve guides
    Tomei Lifters
    Tomei Spec C Spring kit +10,000 rpm
    Tomei Valve seats
    N1 Water Pump
    Cusco Cooling Plate
    Body and Paint:
    Full glass out restoration, Re & Re of any problem areas. Paint with two tone HOK Kandy BrandyWine with a Black roof and A&C Pillars
    Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
    FS: tomei 2.6 full counter crank, reground/nitrated.
    Jan 2004
    West Kelowna
    841
    Ztune has started my RB26 head build.
    Tomei 280 deg 10.8 lift cams
    Tomei lifters,guides,seats
    Tomei Spec C springs
    Tomei Cam Studs
    Oil Drainback
    Portpolish
    Bowlwork
    Short block will be 2.6l.
    Parts in my garage, build starts this winter.
    Tomei Oil Pump
    Tomei Oil Pan Service (Pan Extention)
    Mahle Powerpak 87mm pistons
    Tomei 2.6l Full Counter Balance Crank Shaft
    N1 Water Pump
    Tomei Full Counter CrankShaft
    Mahle PowerPak Pistons "slipper skirt"
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    Is your VIN right? It looks to have an extra digit, unless mine as a missing one lol. I must be crazy. 11 digits is right no?
    lol
    Jan 2004
    West Kelowna
    841
    ya i think you are right
    Jun 2008
    Alberta
    4,233
    oh btw, there's nothing better than good head Sweet looking setup!
    lol
    Jan 2004
    West Kelowna
    841
    With choosing rods i dont know if i should go with heaver stronger Carrillo H beam or Lighter Super-A beam
    488 vs 507 grams
    Jan 2004
    West Kelowna
    841
    added a video at the top
    Banned
    Jul 2009
    Calgary
    484
    hahaha sounds ******* epic
    Jan 2004
    West Kelowna
    841
    Tomei Oil Pump
    Tomei Oil Pan
    GTRCer Chewy's Avatar
    Oct 2006
    Pricktoria , B.C.
    617
    mmmm sexpan.
    1/1_Scale
    パーソナリティは、1つを得る
