400$ for a battery relocation kit? as in 2 lead wires and a box? wow! Nice parts btw!
03 lancer DD
68 gmc w/355 cid rice killer
R33 GTR. The time is near!!
Time update ! 1 april car going to get install all the new parts !!
28 april car going back to dyno ! gonna raise the boost to 22 psi for ultimate last boost setting
1-11 psi
2-15 psi
3-18 psi
4-22 psi
hopefully i will get 550 whp ! at 22 psi thats my goal ! since 4 psi + new rad (colder water temp by 30 celcius car was really hot at dyno day cuz of old prestone n stock rad n oil temp was high too due of hot water temp -- so i guess wit a colder engine temp water n oil i should make a bit more power ) + tomei expreme manifold n dump
all the rest of part not give me any power adder has we know
video coming soon![]()
HALTECH PLATPRO,6 SPEED GETRAG,Precison 62-66 BB, racepack dash display AND MUCH MORE!!
For everyone , wen i bought my car SELLER told me that it was forged came wit a part list ,, (1 week ago while engine was out to install oil pan baffle and spool oil drain needded to take the oil pan out and I FOUND STOCK BOOTOM end , so i sold the engine and bought a new R34 SWAP wit 20 000 km
Here his the FINAL part list wich is 100% complete
Moteur:
Swap r34 2000 20 000km
tomei manifold
Tomei dump
R34 n1 turbo gt2860rs-7
Apexi front pipe
Apexi complete cat back*
Greedy type r BOV
Tomei head gasket 1.2 mm 87 bore
Tomei timing belt
Tomei oil pan baffle
Spool oil drain kit
Grex cams 264*
Toda cam gear
Yellow jacket coil pack
Hks intake wit custom pipe*
Nismo engine mount
Cusco OIL catch can 3 liter wit stainless steel braided line
Drivetrain:
r34 frontndiff
R34rearndiff
R34 6speed getrag (20 000 km)
1 piece allu driveshaft (driveshaftshop)
Nismo twin plate competition model
Nismo r34 tranny mount
Nismo r34 stainlesssteel clutch line
Fuel system:
1000 cc denso injectors
Greddy twin entry fuel rail
Sard fuel pressure regulator
Sard fuel pump wit relay 280 lph+
Cooling system:
hks piping kit*
Cusco divided twin turbo pipe
Arc 4 inch intercooler
Mishimito radiator
Nismo low temperature thermostat
Trust greedy oil cooler wit filter relocaliser
Ecu:*
Apexi Power fc d jetro (map sensor)
Tuning almasi*
Apexi boost control kit
Braking stuff
R34 brembo wit project mu brake pad
Stainless steel braided line
Suspension :
cusco type zero 1 coil over kit
Ams hicas delete kit
Ams front upper table
Ams tension rod
Ams rear
Camber ajuster
Roller:*
17x9 +15 offset work rsz-r*
275-40-17 g force kw2 tire*
Interior:
cusco 7 pooint rool cage*
Nismo gt500 6mt shiftnknob 12mm
Recaro sr4 blue*
Bride low position seat rails
Alpine radio*
Z sport cluster 320kmh
Razo foot pedal
Defi oil pressure gauge
Defi boost gauge
Innovative wide band
Sard battery relocator kit /sard box
Exterior
N1 Headlights
Nismo front bumber
Nismo side skirt
Nismo rear valence
Fluids:*
Tranny;Motul 300 gear oil api-gl4 75w90
Nissan matic d transfer case
Front diff+ rear diff
Motul 300 gear oil 75w90
Engine:
Motul 15w50
Oem oil filter
List is Sweet man.
That thing is going to be a beast with response
Not a bad list, definitely a good balanced build without going too crazy.
Why a 4" intercooler though? That's gonna add lag. A stock r34 intercooler is still efficient at 500whp while having the best response. That 4" beast might make your -7s laggy like our -5s![]()
Black 2010 Subaru WRX. Weekend warrior. For sale. $22k
New ride pending sale on wrx: black 2013 ****
03 lancer DD
