Results 1 to 10 of 10
Thread: GTR RWD Switch. Choose between AWD and RWD with this simple setup.
    GTRCer 550HPTrojan's Avatar
    Mar 2011
    Coquitlam, BC, CANADA
    3
    Thumbs up GTR RWD Switch. Choose between AWD and RWD with this simple setup.
    Here I've illustrated the process of making the dream of RWD power, reality. no need to thank me. enjoy...
    items needed in order to DO-IT-RIGHT
    -wire stripper/ crimp tool
    -16 gauge wire
    -Type 10 fuse tap
    -Male quick connectors
    -Female quick connectors
    -a type 10, 10amp fuse (OEM)
    -a sick looking nitrous switch or any rocker will do.
    (optional)-heat shrink or electrical tape
    OEM english translated fuse panel
    we are going to want to tap into the "AWD" fuse located on the far top left of the panel.
    to do so we will use our fuse tap
    make sure once your custom switch loom is complete, you don't eliminate the original fuse, its easy to incorporate it into your new setup, in-line, like this
    after you have completed this sick, one of a kind loom, you can add your every day run-of-the-mill nitrous switch to top it all off.
    IMPORTANT!!! make sure when you install the female connectors onto the switch you place them in such a manner that they will always be ON and when you want RWD you will open the cover and move the switch into OFF position. Normally switched work the other way around (normally OFF ~ switch to engage), so be careful. you want normally ON ~ Switch to DISengage.
    DO NOT USE THE SWITCH WHILE IN MOTION!!!!! STOP YOUR VEHICLE AND THEN SWITCH THE RWD/AWD ON OR OFF. It is possible to switch it from RWD back to AWD while in motion, although it will not actually do so until you have come to a complete stop for a few seconds.
    once completed, this is the fuse panel.
    and the completed loom
    *update*
    Some of the guides for this modification say to remove the fuse within the engine bay although this fuse in particular is used for the 4WD AND the PTC heater which stands for Positive Thermal Coefficient, which basically is your "rear window defroster" as well as the windshield also has a heating wire which will not work if the engine bay fuse is removed.
    *update*
    Enjoy!
    OO)______(OO
    1991 Skyline GTR R32
    Gun Metal
    PT6265 single turbo build
    640AWHP @ 22psi 8700rpm on a mustang dyno w/ methanol
    All forged internals RB26, just the crank is stock.
    Stock Tranny, will soon die :P
    GTRCer ChuckNorris's Avatar
    Nov 2007
    Regina
    136
    I`m pretty sure i read on here that it is better to pull the fuse located in the engine bay? could be wrong tho!
    1993 Nissan R32 GTR
    GTRCer leeaspin's Avatar
    Nov 2009
    grande prairie
    495
    wrong section man
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    Very nice write up! This will be very useful for lots of people. I would definitely try this out if I wasn't getting a Skylab controller.
    Thanks for taking the time to do the right up!
    ps if I may add, Taking the fuse under the hood out will also disable ABS. I know this because I tried both ways and "4WD" "ABS" lights came on.
    GTRCer NeptuneGTR's Avatar
    Jun 2009
    Winnipeg
    521
    Quote Originally Posted by bellis_GTR View Post
    You know that the tsc only alters the lateral g voltage output, it doesn't disable the awd, only has effect on cornering.
    NEPTUNE OPTIMUS MAXIMUS
    Jan 2010
    London, ON
    1,572
    Is there not a Skylab that has a switch for 2WD and 4WD as well as a 1-10 dial for how much torque to be sent up front?
    Or am I thinking of another company?
    GTRCer bobbo's Avatar
    Aug 2009
    Halifax Nova Scotia
    1,010
    ^^Sounds like the Extreme TSC to me^^
    Jun 2009
    Winnipeg
    521
    yep, thats the exteme tsc.
    Jan 2010
    London, ON
    1,572
    Great thanks for clearing that up. Im lucky I haven't placed the order yet.
    kengeroo's Avatar
    Apr 2010
    vancouver
    591
    this is only good for a r32, correct ???
  1. Torque Split Controller or simple switch
    By bowes in forum GT-R Tech
    Last Post: 09-17-2009, 11:38 PM
  2. ECU choose, need help
    By shift_Z in forum GT-R Tech
    Last Post: 08-08-2007, 05:18 AM
  3. WTB: A/C Setup & RB26dett Intake Manifold Setup
    By heatw in forum Parts for Sale
    Last Post: 07-11-2006, 03:33 PM
  4. Choose between two Nissans
    By gtrr34aidid in forum General Skyline Discussion
    Last Post: 02-23-2006, 03:09 PM
  5. Wich choose
    By Giguer in forum General Skyline Discussion
    Last Post: 10-07-2005, 09:49 AM
