Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: The Build From Hell
    Jan 2010
    Manitoba
    216
    The Build From Hell
    After buying my p.o.s. 92 a year and a half ago I am finally able to start working on it. Unfortunately fate would start to throw me curve balls and some legal issue ate up the cash I planned to put in her.
    I picked it up fairly cheap knowing it needed some body work and some parts were swapped over from a GTS (hood and seats). The right rear quarter was starting to rot and generally needed some tlc.
    When I first got her:
    After sitting in a damp garage from December 09 until three weeks ago the cancer grew
    So I started getting parts together from Nissan and members of the forum. Parts list so far is: new quarter, rocker, grill clips, vented fpr hood (replaces GTS), carbon fibre grill (didn't have one), R*SR adjustable struts, stock front strut brace, Ikeya rear camber arms, front rebar(missing original), stock intercooler (original has bottom three rows mashed) and hood hinges(more on that later).
    To kill time while getting parts together I figured, "might as well do a comp test" so my neighbour and I fire it up and go for a cruise around the block to warm it up. Just as I shift to third at about 60-70kph I remembered the hard way that the GTS hood didn't always latch properly as it folded it's self over the roof. (Yay first the rust now the hood
    After getting the hood "straight"
    To keep my self occupied while hunting for parts I started project "DOT" and personalized my head lights a little.
    Project "DOT" plugs being made for vac-forming.
    Light housing, stripped the chrome and painted black.
    My sheet metal arrived Tuesday so I started the tear down, now I'm really starting to think "somebody" hates me, lol, the previous owner didn't take any care in jacking the car and mashed the rocker/floor seams and pushed the floor pan up 2-3" in the front passenger foot well. Strike three, I'm almost ready to do a "Cobain" at this point!
    Damage shots
    What ever, life goes on, I figure out how to get it straight again.
    Now for the final blow that has me thinking that hell is on earth and I'm the sole occupant. I need to pull the windows out to do a proper job of replacing the quarter, not a big deal. Then it starts going down faster than the Titanic. The friggin nut on the wiper motor holding the seal to the glass is corroded to s**t. I cleaned it up with a dremel so a wrench would fit, hit it with penetrating oil, then let it sit overnight. Went out today spayed more lube, got the socket on, and it turns! And turns! And turns....stripped. I find a screw driver and get under the nut and start again, hey it's working! It's almost off! Disaster strikes again, wrench slips, I hit against the screwdriver and...
    So that's the story for now, hopefully it's all aces from here out and the progress updates will be happy times
    Quote Originally Posted by Snow View Post
    Sure a condom holds water but you don't see me drinking from one.
    GTRCer ColinR33's Avatar
    Oct 2009
    Edmonton, AB
    479
    Damn! That's gotta be frustrating, hope it starts going better for you. I can empathize with the jack points - mine is much the same. As for the rest, all I can say is good luck!
    Eat_Sleep_Shift's Avatar
    May 2007
    Saskatchewan
    145
    I did the exact same thing to a friends window when i tried taking the wiper out, almost had it.............and boom! I hope everything goes smoother for you on the rest of the car! the black housing for the headlights looks good! i have always liked that look.
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    lol ya mine was coroded really bad also, the BEST way to get it out is to mask off the surrounding window, then take a course file and just work on one side of the nut carefully untill you can see the threads. then you take vicegrips and grab on it the same way you would with regular wrench and turn the nut. it will bend open and fall off.
    i was trying other stuff, but after a couple close calls with the glass i had a brain storm :P ^safest way imo
    A. Nash
    GTRCer future_R34's Avatar
    Jan 2009
    Appleton, NL
    151
    Lol, there's a place in car heaven for all of us when the time comes!
    GTRCer Bruizer's Avatar
    Oct 2006
    1,504
    Have you thought about parting out/scrapping the rest and buying a cleaner car? It's a lot of work to get this baby back to normal. There's many skylines available still today. You'd probably get your money back by parting out, the you can buy a nicer one, most likely for less than the labour and repair costs this one would run you. Just an opinion.
    No build thread.
    1991 nissan
    El terror
    Da Nismo Kid Oakville's Avatar
    Sep 2007
    Oakville, Ontario
    4,466
    I agree with Bruizer on this. I see youve already bought new body parts but there are newer cleaner shells rolling around for moderate prices
    Aug 2010
    Courtenay , BC
    1,054
    i agree, even the rear window show you can see the rust along the bottom. ALOT of work
    A. Nash
    Apr 2008
    canada
    1,810
    Brutal ownership so far man, we feel for ya!
    Everyone I know who removes the rear wiper assembly has the same corroded nut... our solution was typically to use a dremmel cut-off disc and just chop the whole thing off.. lol
    in pleace that you won't replace the metal and just want to stop the rust spreading, I strongly advise you look into a paint callec "POR-15" I've used it a whole bunch under my chassis for rust prevention.. it dries to a rock hard finish and NEVER rusts again... promise! lol
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    Part out and pick up a clean shell. Car looks about ready for the crusher, man. Rust under the window and ****? Not worth the headache and heartache that will be sure to continue to flow.
  1. Replies: 59
    Last Post: 05-08-2012, 07:39 PM
  2. 4wd light from hell
    By DBar in forum GT-R Tech
    Last Post: 10-30-2010, 02:59 AM
  3. What the hell is with the weather?
    By Inline Slut in forum GTRC OT Pit
    Last Post: 02-06-2008, 09:09 PM
  4. WTB: DSpeed Hell Cat Kit
    By dudie in forum Want to Buy
    Last Post: 09-19-2007, 09:24 AM
  5. WhaT The Hell Is With the Weather!
    By SalEsh in forum Western Region
    Last Post: 03-31-2005, 10:50 PM
