Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Chris' BNR32
    GTRCer christdeyoung's Avatar
    Sep 2008
    Antigonish, NS
    399
    Chris' BNR32
    Well, my first build thread got deleted or something it seems, so I'll write up another quick one.
    Made 310rwhp for a break in tune and leaned out on the stock fuel pump....new one on the way. This is a street machine only so I'll be lookin for somewhere in the order or 500 - 550 whp. I'd like to run quite a bit more, like in the 700+ range on Q16, but that's in due time. I have a sneaky suspicion that the stock R32 transmission will hold up to that power level as long as the operator isn't thrashing into gears and drag racing it.
    Manley I beams, CP pistons, ACL bearings, ATI race damper.
    Tomei 270/10.8mm Procams IN/EX, Tomei adjustable cam gears, Tomei lifters, HKS seals, Tomei studs, Manley springs/retainers.
    6boost twinscroll T4 turbo manifold, set up with two 38mm flanged tials to open dump. GT4088, Tial 50mm BOV, 3" custom downpipe/precat, 5zigen catback.
    Nismo front LSD, Bully single disc stage 4 clutch.
    Tomei sump baffles, head restrictor, external single stage Moroso oil pump with an 3qt Accusump on a solenoid and a pressure switch. (likely going dry sump soon....speaking of which, the cost to build your own is a lot less than what most people figure...If you can weld your own tanks and sump, you could dry sump a car for the same cost as a JUN or Tomei pump/baffle setup). My oil filter and oil filter head assembly are now being held by what previously held the carbon canister lol.
    1000ID's, HKS 11mm rail, AEM regulator, Deatschwerks in tank fuel pump. AEM EMS1, wideband controller, EGT sensor, and it's running a MAP setup.
    Hicas is gone, power steering gone, AC, gone.
    Now for a few pictures.
    Annnnnnnd, everyone loves the cat!
    That's all for now! I'm sure the list is vastly incomplete, but that's the meat and potatoes.
    Sep 2008
    Antigonish, NS
    399
    Ignore the timestamps, they're a year off.
    cschepp's Avatar
    Jan 2008
    _________________
    4,321
    Sharp looking car man. Just out of curiosity though. If you want to just drive it on the street then why do you wanna make so much power? That much power would bit a bitch on fuel and if your insurance finds out they will just drop you. Looks great thoug
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    Sep 2008
    Antigonish, NS
    399
    Damn, wtf....I even searched for threads created by user and I couldn't find it.
    Anyways, I only have PLPD on my car and she said that it doesn't matter how much horsepower it makes.
    Really only looking for big horse for occasional drag or track days....and some street use. Q16 is like 35-40 bucks a gallon or something so obviously I wouldn't be DD'n it that way.
    6-750awhp would be nice and streetable though!
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,893
    damn ur build is boss! pretty similar to mine.
    Sep 2008
    Antigonish, NS
    399
    Yeah? What are you getting for vacuum then? lol
    My intake is degree'd to 110 ATDC, and the exhaust had specified 115 BTDC...it was at 117 with the stock pulleys, and I moved it to about 114. No increase in vacuum...
    I'm going to play around with the intake cam to try and improve the vacuum....right now I'm only getting about -5 to -6 psi (20-25 cmHg) at idle, and not a whole lot more during decel.
    Banned
    Oct 2010
    Mallorytown,Ontario
    1,024
    noob qustion..whats the blue tubular obejct by yur grill?
    GTRCer leeaspin's Avatar
    Nov 2009
    grande prairie
    495
    Quote Originally Posted by trickey1991 View Post
    kinda looks like some sort of accusump
    Sep 2008
    Antigonish, NS
    399
    Yeah, 3qt Accusump and solenoid/pressure switch assembly (not visible).
    For prelube and for protection against oil pump/belt failure.
  1. Lhd bnr32
    By GodZillaa in forum Media
    Last Post: 04-01-2011, 06:22 PM
  2. FS: M's Intakes & BNR32 MAF's for BNR32
    By JDM-IMPORTS in forum Sponsor Forums
    Last Post: 08-13-2006, 04:37 PM
  3. BNR32/33/34
    By boost-god in forum GT-R Tech
    Last Post: 04-26-2006, 03:42 PM
  4. WTB/WTT BNR32
    By CSMRX7 in forum Parts for Sale
    Last Post: 02-21-2005, 12:06 PM
  5. Aug/89 BNR32 at JNS
    By JZ in forum The Auction Block
    Last Post: 03-07-2004, 05:58 PM
