Results 1 to 6 of 6
Thread: my r32 sedan project
    GTRCer koreymj's Avatar
    Jul 2012
    montreal
    5
    I bought my skyline on monday off a friend who decided, on monday, to sell it. It was an opportunity I couldn't pass on, my first plan was to purchase an s13 and throw in an ls3 as a drift car. Plans change and I think it may be for the best!!!
    These are parts that are on the car and also not installed yet.
    SUSPENSION:
    - DRIFTWORKS Multi-Link kit ALL ADJUSTABLE WITH BEARINGS includes Front adjustable tension rods, Front upper camber arms (GTR/Q45), R33 style rear upper control arms, Rear traction arms, Rear lower control arms HICAS eliminator kit
    - Buddy Club N+ Spec racing coilover system with Pineapple bushings and Spherical bearing camber plates. 38 way damper adjustable
    - GTR Rear subframe, sandblasted and powder coated black. Solid aluminum bushings with adjustable height collar (for raising or lowering the subframe),
    - GTR front subframe, sandblasted and powder coated black, includes front lower control arms with new inside ball joints
    - GTR differential, LSD with 1000HP axles and the driveshaft yoke.
    - GTS rack and pinion with urethane bushings, URAS forged inner tie rods (with machined 3mm spacer) Ikeya formula rod end outter tie rods with GTR and GTS pins
    - GTR hand polished spindles (front and rear) bearings, with 55mm extended wheel studs. Front King pin arm sandblasted and powder coated black
    - GTS gas tank
    - R32 headlights, N1 style, OEM
    - RB26 N1, 24U block code (highest Nickle content block), freshened up 3 years ago. Long block
    - R32 GTS 4 piston front, 2 piston rear calipers. Rebuilt with new seals and boots, powder coated GOLD with RED Nissan
    - Powerslot 14" Rotors for G37, Zinc coated, cross drilled and slotted
    - Apexi N1 exhaust system
    - 2x XXR 502, white, 18x9.5" +35 offset, Federal 595 225/35ZR18 mounted and stretched
    - 2x Fast Wheel Enkei RPF01 replicas, without tires
    - 2x Fast wheel 19x8 with General Tires
    -Apexi DECS 5" tachometer, Oil pressure and temperature LCD display White backround to 11k
    - PLX Devices IMFD datalogger, Live Tune.
    Chassis
    -1992 r32 sedan, stripped interior undercarriage gravel guarded, engine bay and interior painted astro blue. Molded gtr tail lights
    What I am getting
    -twin gt28-60
    -tomei manifolds
    -greddy intake manifold
    -750cc injectors
    -2x38mm wastegates
    -greddy profec spec b2 boost controller
    -greddy ls intercooler
    -mishimoto rad/fans
    -rb25 tranny
    -aluminum driveshaft
    -hks hyper single clutch
    -2jz fuel pump
    -aem ems
    -painless wiring harness
    -N1 revised oil pump
    -greddy tru time timing belt
    Thats just a quick list more to come. Advice, criticism and feedback all welcome first time building a skyline.
    Jul 2012
    montreal
    5
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,414
    I like man, Whos going to tune that beast for ya? Hydro ebrake and your set?
    92 Gtst/Silver bullet
    GTRCer MidnightBlue's Avatar
    Oct 2010
    Coquitlam, BC
    35
    This car looks like its gonna be going side ways more than frontways around mad corners lol, you got a gem man
    Its not just a car, Its a Life style
    Da Nismo Kid Oakville's Avatar
    Sep 2007
    Bronte Creek, ON
    4,988
    that looks like takahashis old car...
    Jul 2012
    montreal
    5
    nope, still finishing up the body, cut 1/4 panel to set flares, then first coat of primer more sanding then paint. cage being done soon, have my head to assemble with tomei goodness , keeping stock cams. Run my brake lines, cut trunk and fab up a bracket to hold the fuel cell while using the oem filler neck. Run the ss line for hydro ebrake. Stil lots of planning and thinking ahead!!!
  1. Replies: 15
    Last Post: 01-17-2012, 03:55 AM
  2. 89 R32 GTS-T Sedan
    By Stuntmonkey in forum Cars for Sale
    Last Post: 09-21-2011, 04:27 PM
  3. '89 GTS-t Sedan
    Last Post: 07-07-2011, 08:28 PM
  4. WTB: R32 Sedan?
    By mvs2 in forum Sponsor Forums
    Last Post: 05-29-2011, 05:18 PM
  5. My old GTS Sedan
    By eastbeargts in forum Want to Buy
    Last Post: 09-21-2010, 08:04 PM
