YAY!!.....
finally have a page for Project cars....
Engine
-RB30DET
-Greddy T78 single turbo
-Greddy intake manifold
-Custom Exhaust manifold (braced)
-ACL forged pistons (ceramic coated)
-SPOOL forged rods
-balanced / polished crank
-N1 oil pump
-Keep Labs custom external oil pick up
-Keep Labs custom external oil return (turbo/head)
-N1 water pump
-Greddy racing BOV
-Greddy 50mm waste gate
-Electric fans FAL Twin 12"
-F-win Rad
-ARC oil cooler (grill mounted)
-Removed ABS, Custom brake lines (hidden)
-Trust 100mm intercooler
-Areomotive FPR
-HKS 280L fuel pump X2
-Nismo 275L fuel pump x1
-Powerflow fuel filter (x2)
-Black Stainless lines
-Sard surge tank + Stainless fittings
-Earles stainless lines
-Grex 272 cams
-SARD 1000CC injectors
-ARC Ti cooling plate
-Trust coolant breather tank
-Custom 100mm stainless Keeps Lab exhaust
-ACL bearings
-ARP Bolts
-Tomei Type B Head Kit
-Custom Head shims
-Tomei sump baffle
-Nismo engine mounts
-Custom Catch Can
-Custom rad overflow tank
-Racing Battery relocated to trunk
-Gates RB30 timing belt
-Tomei 1.8mm 87”metal head gasket
-custom anodized earls fittings GOLD
-Greddy 100mm intercooler pipes
-HKS turbo bell mouth
-Greddy over size pully kit
-ATI crank dampener
-Samco rad hose
-Split fire coil pack
-Custom 4wd sump adapter plate
-Billion Power Steering fluids cooler
DriveTrain
-6spd trust dog box H pattern
-Push Pulled conversion
-OS Giken triple plate clutch
-Push to pull type Conversion kit
-Essential strengthen clutch piston kit
-Cusco front 1.5 way type MZ lsd
-Tomei T-trax rear 2 way lsd
-Nismo Steering rack bushing
-TEC Metal Steering rod spacer
Interior
-KTS 7pt Rollcage (custom padding)
-recarpeted rear floors
-Bride Zeta3 (L) bucket (driver)
-Bride Gias Carbon Kevlar (passenger)
-AC unit relocated to Glove box
-HKS Boost controller
-Defi Link Water temp. guage
-Defi Link Boost guage
-Defi Link oil Temp guage
-Defi Link oil Press guage
-Defi Link Ex temp
-Defi Link Fuel pressure guage
-Privat Speed meter
-Defi 80mm Tach 11000rpm (white face)
-Defi Link indicator II
-Custom Carbon Kevlar cluster
-Custom Carbon Kevlar center console
-Custom carbon center glove box
-Toggles switches / push start button
-Power FC Controller
Exterior
-Greddy rear skirts
-Nismo f-bumper
-Custom Carbon bumper Lip
-Custom Carbom N1 side skirts
-Custom Carbon hood lip
-Custom Carbon N1 ducts
-Custom Made Angel Eye N1 headlights
-D-Max Carbon Hood
-Custom LED rear License plate lamps
-Sard GT Spec M Fuji 1700mm wing stands 1210mm (Carbon Kevlar)
- Custom CNC Wing Stands
-Blitz I-Spark headlight blinker
Brakes / Suspension
-Cusco Tension rods
-Cusco rear camber arms
-KTS front camber arms
-VTTR Front 6pot 2pc rotor racing brakes
-VTTR rear 6pot Racing brakes
-HKS Hyper Max coilovers
-Metal sub frame spacer
-Cusco front & rear sway bar
-Custom over size Endlinks
-KTS lug nuts
-ALL Nismo hard bushings through out
-Seem welded suspension tower
Check below for pics
pic #1....
No need to c pic one !
pic #2, taking out the engine cuz #6 piston only had 25psi
pic #3, engine outa the car
pic #4, off the valve cover, there we found Grex Cams (unknown size)
pic #5 Grex !!
pic #6, pistons (1-4 was good, 5 had half melted rings, #6 doesn't have rings, and a hue hole on the side of the piston )
pic #7, Newly painted engine cover.
pic #8, Forged pistons and rods
pic #9, stage one of my center console, (it's being revised ! )
pic #10, my Greddy intake manifold, OEM on it's side
pic #11 custom LED tail lights
pic #12 Custom Ti 3" exhaust
pic #14 racing battery relocated behind passenger seat
pic #15 ARC oil cooler
pic #16 ARC oil cooler mounted in my custom cut-away grill
pic #17 Sard wing still in packaging
pic #18 Carbon Kevlar exhaust heat shield
pic #19 Custom Carbon front lip
pic #22 D-max carbon hood
pic #23 block deck height
pic #24 forged piston and rod before ceramic coating
pic #25 6 spd tranny
pic #26 6 spd shift knob
pic #29 grill painted black, carbon lip installed
pic #30 another view of my car as of oct 12 06
pic #31 exhaust guard installed
Tomei 2way diff
Front Cusco 1.5way diff
turbo mouth
ATI Crank Dampener
Greddy Turbo
painted engine bay
finished rb30 block
VTTR brake calipers front/rear
more to come.
LinkBack URL
About LinkBacks
