So far from the day it all began I'd say its been a very
positive experience working on my own car.
Origionally the car came with a Mines ecu,an HKS timer and a stock drivetrain.
So far the turbo timer is the only thing thats stayed in the car!!!
Present Mods:
Apexi Power FC w/Commander
Sard 720cc's
HKS AIC (Not installed yet)
HKS SSQ's x 2
HKS VPC
Mallory 4port FPR 1:1 riser
Bosch 044
Greddy Catch x 2
Irridium Plugs
Greddy Timing belt
N1 Water pump
Samco Upper/Lower hoses
Modified fuel rail to duel feed
Eboost2 boost guage/contoller
Warner EGT gauge
Warner AF gauge
Innovative Wideband w/RPM datalogging
Toshiba Laptop (for road tuning)
Recaro drivers seat
Battery relocated to trunk
Top mount single turbo manifold
Garrett GT42R
Custom 4" down pipe
HKS wastegate
Custom 5"intake pipe w/K&N cone filter
Custom 3" piping to intercooler
XS intercooler
Vibrant hump hose
HKS Triple plate clutch
Redline oils throughout
Filter Relocation kit
Torque split controller
3.5" Cat back system not sure of the make yet but will do
a back pressure check to see if its too restrictive
With all these mods I know I was running in the 480whp
range @ 21psi on pump 94octane.
New Mods already in progress:
All Stress rises removed and polished
Jun Crank collar
Micro polish crank journals
Removed "Bulls head design from Counter weights"
Replace all crank oil gallery plugs
Balance crank
Balance clutch
Check balance of new Ross Harmonic balancer
Stress relieve and Cryo crank
Block has had all the casting flash remove for stress relief
N1 oil pump
15 row oil cooler
Argo "I" beam rods
86.5mm Wiseco piston Teflon coated skirts and ceramic tops
ARP Head studs
ARP Main studs
ACL Bearings
Custom oil baffel
Tomei Gaskets
Tomei Poncams
Tomei Valve springs
Tomei Retainers
HKS valve seals
STR Cams gears
STR fuel rail
Nismo engine mounts
JJR torque mount
Combustion chamber work
Port match and polish
Tranny is an OSG type "A"
Larger R34 Koyo rad
Future upgrades.....
BRAKES I NEED BRAKES......(Most likely VTTR's)
Brake master cylinder and stopper
2nd Bosch 044 and fuel cell or swirl pot
Rims may need to go to 18's for caliper clearance Bee R's in white or Polished
Roll cage that reasonably street usable
Subframe braces custom fab
Chassis reinforcement
Ohlins Coil overs
Heres the car when I got it in 2005 December
The Stock engine
Detailed the engine bay with a few mods already started
Single Turbo
Custom inlet pipe and K&N
Custom 4" Dump pipe & Wastegate
HKS Triple plate
Mallory FPR
For now I'm waiting on the bottom end parts and machining
Its been at least a month since it came off the road and all I want to hear is it running again gonna goes nuts this winter :hit_head:![]()
LinkBack URL
About LinkBacks
