I have started to collect some of the parts for my engine build. This is a long term project as I am going to school and trying to start a business.
1989 GTR BNR32-001551 imported in September of 2004 and only drove for a month as I lived in Kamloops and the snow fell. during the winter I started a full performance build that has not finished yet. To date I have done many things, too many to list here. so this post will primarily consist of the my experiences tuning a internally stock rb26 and then my subsequent engine/transmission build, install and then tune.
Tuning:
Apexi PFC
Motec PLM
FC Datalogit V2
Spec List:
BNR32-001551
ATL 22 gallon Fuel Cell with two surge tanks
Bosch 044 pumps * 2
Canton 1 micron filters
Earls Check Valves
-8an * 2 Feed lines
-8an Return
Sard 800cc green top injectors
Sard fuel rail
Sard Type RJ Regulator
Battery mounted in trunk - Custom box
Re and Re rear sub frame powder coat black
NEW wheel bearings rear
Re and Re CV boot kits rear
Nismo Long Studs F&R
Energy Poly Bushings
Removed Hicas,A/C, Park Brake
Defi BF Guages, Tac,Pyro,Boost,Oil Press,Water,Oil Temp
Apexi PFC,Controler, Boost Kit
Z32 AFM's new
Trust 600*300*115 IC
Trust T618z
Trust Front Pipe 2 pc
Custom recirc BOV kit
Trust Raidiator
Trust Coolent expansion tank
Trust Oil Catch
Trust Hard Pipe kit
Trust Oil Cooler Relocate thermo
OS Giken Superloc Rear
Cusco Tension Rods Front
Cusco Front Upper Camber -5mm
Cusco Front Sway Bar
Cusco Rear Sway Bar
Cusco Rear Upper link
Cusco Rear Toe Bar
Cusco Rear Strut Bar
Nismo Front Strut Bar and Master cyl stopper
JIC Magic FLT-A2 Coilover 10 kg F 8kg R
Custom Ti Exaust 90mm
Custom Test Pipe with WideBand
Motec PLM
F50 Big Brake Kit Front
Nismo LM 17" Wheels
Nismo Engine mounts
Nismo Transmission mounts
Tomei 280 deg 10.25mm ProCams
Tomei Oil Pan
Tomei Oil Pump
Tomei Bronze valve guides
Tomei Lifters
Tomei Spec C Spring kit +10,000 rpm
Tomei Valve seats
N1 Water Pump
Cusco Cooling Plate
Body and Paint:
Full glass out restoration, Re & Re of any problem areas. Paint with two tone HOK Kandy BrandyWine with a Black roof and A&C Pillars - In progress as we speak.
Future Mods or Mods in Worx
ATI 1000hp Damper
ACPT carbon Prop Shaft
OS Giken R3C Triple Plate clutch
OS Giken RB31
Phitzer Straight Cut Gear Set
Full Titanium Cage
1.5 way Front Diff
Diff,G-Box,T-Case Thermo controled oil coolers mounted under rear fuel cell.
Goal is for a reliable well balanced Time Attack car running around 800-900 AWHP. Car arrived completely stock and i have done all work myself except for body/paint and installing/clocking the rear LSD and Welding up the Cage for the ATL fuel cell.
LinkBack URL
About LinkBacks
