Results 1 to 6 of 6
Thread: **air/fuel** meter install
    GTRCer typerrr's Avatar
    Sep 2006
    montreal
    142
    witch wire i need to spline to connect the air fuel meter,
    thank s
    1989 SKYLINE GTR
    KAD paint
    FMIC
    HKS bov & piping
    TWIN 3in DOWN PIPE
    FREE CAT
    4in CATBACK
    STAGE 4 CLUTCH ( 6 puck )
    N1 OIL PUMP
    STEEL WHEEL TURBOS
    N1 RODS
    WISECO 87 MM FORGED PISTONS
    ACL MAIN & ROD BEARINGS ( std )
    COMETIC HEAD & BUTTOM END
    SIEMENS 750CC INJECTORS
    WALBRO 255
    12.3 @ 112MPH
    Sep 2004
    Fort Nel$on, BC
    364
    I think its the black wire but my memory is a little foggy.... just get a multimeter and test for voltage... test each wire... the wire that that goes up in voltage when you rev it up is the signal wire.
    1990 Skyline GTR Nismo #161
    Mar 2007
    Peoria, IL USA
    52
    Is this a wideband meter or a narrowband meter? There needs to be more info in this thread to gather a correct answer.....
    I may be getting a little ahead of myself but if you are trying to install a narrowband meter I would stop, return it, and save your money. They are worthless
    Sep 2006
    montreal
    142
    Quote Originally Posted by Booztd 3 View Post
    i was going for the ngk afx wideband,but a narrow band is easier to install,what it s no good...
    1989 SKYLINE GTR
    KAD paint
    FMIC
    HKS bov & piping
    TWIN 3in DOWN PIPE
    FREE CAT
    4in CATBACK
    N1 OIL PUMP
    STEEL WHEEL TURBOS
    N1 RODS
    WALBRO 255
    12.3 @ 112MPH
    GTRCer Danno's Avatar
    Mar 2006
    Victoria, BC
    940
    Narrowband AF meters are even more useless than those horsepower guages. Have you ever seen one in use?
    If you have a narrowband, definitely return it, and either spend the money on a real wideband kit, or put it to something more useful like gas for the car.
    GTRCer nissanconvert's Avatar
    Mar 2006
    527
    and wideband is basically plug and play
