Results 1 to 7 of 7
Thread: Question about Oil Pumps
    Feb 2005
    207
    Question Question about Oil Pumps
    So I just picked up my beautiful GTR
    (let me add that OMG is it ever no comparison to my old GTS-T, couldn't be happier)
    Anyways...
    People are telling me that Oil pumps are a huge issue with these engines. Now the search buttom didn't produce much of anything, so i'll ask
    Do I need to worry about it?
    I'll give you a little history on the car.
    It's a 91 GTR. Original one owner car. True 100K kms. The only mod on the car is cat back exhaust. It's 100% mint, very well kept and not a spot of rust.
    It has had recent timing belt change, oil change, water pump, coolant flush, spark plugs and much more.
    Would you say the I need to change it? Currently the Oil pressure gauge is reading a steady 4 pounds.
    And if you say I do need one, what kind.
    Thanks guys!
    GTRCer donk_316's Avatar
    Jul 2006
    Edmonton, AB
    1,273
    700hp supra vs my 600hp Skyline GTS
    Two posts above yours as a sticky. Also the FAQ has a shitload of info as this comes up alot. Good luck!
    PS / Pull the engine, change crank / add oil pump drive collar, enjoy engine.
    '08 HD FXSTB: Denim Black, V&H Big Rads, V&H Fuel Pak, K&N, HD Inverted Front End, C&C Seat
    '78 HD 93" Shovelhead rigid, 4spd, 3" open primary, 250 rear tire, 40 rake. (in progress)
    '90 GTR 2 tone 350z blue/black, Volk TE37s, Greddy intercooler and suction kit, Blitz BOV, Splitfire coils, Greddy gauges, HKS oil filter relo / oil cooler, Rear LSD, HKS hypermax II suspension, soon to have new turbos.
    Feb 2005
    207
    HA! well look at that.
    Thanks
    Feb 2005
    207
    Ok well I read through lots of those threads but one quick question to clarify
    I intend on keeping my car 100% stock. Those issues seem to be related to modding it. If I keep it stock do I still need to do that?
    Banned
    Aug 2006
    5,913
    If you plan on keeping your car stock but reving it to 8000 rpm(stock red line) i would recommend a ATI Harmonic Balancer(the small one)
    at around 7200-7600 there is a harmonic that wont be caught by the stock crank pully and a few blocks i have pulled apart have had cracking which could be related to this.
    Now the oiling issue can present itself in stock engines as well as modified engines.
    It is a big job to sleeve the crankshaft snout and replace the oil pump.
    only one guy that i know of has removed the oil pump with the engine still in the car but even then you would not be able to sleeve or change the crankshaft.
    Jun 2006
    Calgary Alberta
    239
    i was told if you leave engine in car
    its a minum 15 hour job.
    Banned
    Aug 2006
    5,913
