Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Like Tree1Likes
Thread: R32 GTR Fluid compartment list
  1. #21
    Dec 2007
    Quebec
    3,947
    are those oils still up to date? I'm about to do a major flush and might change every single oil.. All those recommendation are still good?
  2. #22
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,915
    Up to date as in?
    If you have an oil cooler, that's more oil.
    For example, an oversized oil pan and cooler/relocation kit would mean MUCH more oil
    If I recall, I used to fit about 4.7L of oil in my stock GTR. The other values are pretty close.
    Black 2010 Subaru WRX. Weekend warrior. For sale. $22k
    New ride pending sale on wrx: black 2013 ****
    lol
  3. #23
    Dec 2007
    Quebec
    3,947
    What do you think of the mix MT-90 / lightweight shockproof.
    I emailed REDLINE and they said we should put MT90 in our tranny.
  4. #24
    PL_GTR's Avatar
    Oct 2008
    Vancouver
    969
    Anyone use Royal purple for the tranny oil change and could a nissan dealership have the attessa fluid?
    R33 Skyline GTR VSPEC (White)
  5. #25
    Jun 2008
    Alberta
    4,915
    If I recall, the atessa fluid is Nissan automatic D or ATF.
    As for the gear box, I only use AMSoil and it works fine, no noise great feel, 5 years now on the same oil (until last september that is)..
    lol
  6. #26
    Feb 2010
    Ontario
    105
    Quote Originally Posted by Mr. Anderson View Post
    Well I did a little bit of searching...
    8. Atessa AWD fluid - (Nissan Power Steering Fluid or dextron 3)
    Nope, I did a massive amount of searching, and I've actually pulled fluids from the transfer case ("Matic D") and ATTESSA tank, and they are completely different!
    "Matic D" or Dextron III is far too thick for the ATTESSA system, it is a very syrupy fluid, where the ATTESSA fluid is very water-like. (I can upload a video, if anyone is interested...)
    Nissan themselves warn against using viscous fluids in the ATTESSA system, as it will dramatically increase the latency of the system, which could be very problematic.
    If you can't find the "Nissan Power Steering Fluid Special: KLF30-00001" (which is very likely!), then a cold-weather power steering fluid would probably be the best alternate, but be sure to completely purge the system of the old fluid.
    Dat's it!
  7. #27
    Jun 2009
    Coquitlam, BC
    303
    I'm aware this is super old and I'm sorry for bumping it but is
    what I should use for a GTS-t?
    And if not what? Any power steering fluid fine as long as I completely flush the system first?
    Obviously i mean for my power steering, not attessa.
    EDIT: Wow just realized this is in the gtr section. I fail.
    Sorry!
    Sideways is the best ways.
  8. #28
    Feb 2010
    Where the moose live
    90
    For the front and rear diff if it's only summer driven wouldn't a 75/90 synthetic be ok?
  9. #29
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    2,044
    Quote Originally Posted by toyota86 View Post
    PS.
    Many people recommend running the Nissan PS fluid for the Atessa System. The Nissan Power Steering Fluid Special has part number 10130-89901A and they are sold in 1L containers.
    It should say on the bottle:
    10130-89901A
    Automatic Transmission Fluid
    Special Blend
    Matic - D
    I'm not sure if that part number is the same as the actual "Nissan Power steering Fluid Special" referred to in the manual. I only found that p/n in a thread on skylineaustralia, and the guys said:
    Black squarish bottle - white sticker usual red/blue stripes - says:
    Nissan
    Special Blend
    Matic-D
    Part number on the invoice is the number in my last post. Bottle also mentions to use it as power steering fluid for R32 GTR.
    They told me that this is the stuff to use for the HICAS reservoir.
    http://www.skylinesaustralia.com/for...968.html&st=20
    And this is what the bottle looks/looked like:
    This is why I'm skeptical, since the manual says to use different fluids between HICAS and ATESSA, and this Nissan bottle says its for HICAS.
    According to this: http://www.nissan-sp.co.jp/oil/
    ◆ E-TS fluid
    [E-TS only fluid car]
    * E-TS · · · electronic Torukusupurittoshisutemu
    Packing Part number Suggested retail price
    (Tax included)
    1L KLF30-00001 992 yen
    4L KLF30-00004 3,969 yen
    From what I've read it would appear that the difference with this "Special" PS fluid is it's viscosity at lower temperatures (as in it was taking into account that the car would see winters and snow). So if you only use your car in the summer (I think this is the case for most people here), then ATF/Dextron III shouldn't be an issue in the ATESSA reservoir.
  10. #30
    GTRCer krarks's Avatar
    Dec 2008
    Regina, SK
    153
    ^ That makes perfect sense. I bet even running a synthetic ATF through the ATTESA would eliminate any issue cause I have a feeling that's all that "Special" fluid is.
    1992 Nissan Skyline GT-R - SOLD
    1995 Subaru Impreza WRX STi Type-RA
