Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: R32 GTR Fluid compartment list
  1. #31
    GTRCer leeaspin's Avatar
    Nov 2009
    grande prairie
    495
    im using royal purple in my tranny....works great..very smooth
  2. #32
    GTRCer 326_godzilla's Avatar
    Aug 2009
    Mississauga
    262
    Hello All,
    Can someone point me in the right direction? I went to JRP and called around for the diff fluids but no luck.
    Front Differential - 85W90
    Rear Differential - 80W90
    Can someone recommended brands / shops that carries the above? I want to get the diffs done prior to storage.
    Thanks in advance!
  3. #33
    GTRCer menace's Avatar
    Sep 2011
    Oakville, Ontario
    39
    I looked all over the GTA and could not find them. I did find posts of people saying they use the 75w90 stuff for both their diffs. I have also seen threads where people say that its better if you drive your car really hard.
    I went with the Royal Purple 75w90 MAX GEAR from JRP, which is a bit on the expensive side, about 30% more then the you're going to pay for RP at one of those I might get stabbed here kind of shops in Toronto. The type that seem that have nothing but CF and CF Kevlar hooded Civics and CRX's parked all around and are in some out of the way body dump industrial area.
  4. #34
    Apr 2011
    toronto
    105
    Quote Originally Posted by toyota86 View Post
    I searched around and gathered some information on fluid capacities and such for the GTR. Thought it would be good to add to the sticky. correct me if im wrong. I'm not 100% sure of them.
    1. Engine Oil 5.3L
    2. Power Steering w/hicas 2L (enough for flush and bleed)
    3. Transmission 4.1L
    4. Transfer case 1.8L
    5. Atessa 2L (enough for flush and bleed)
    6. Front Differential 1L
    7. Rear Differential 1.5L
    PS.
    Many people recommend running the Nissan PS fluid for the Atessa System. The Nissan Power Steering Fluid Special has part number 10130-89901A and they are sold in 1L containers.
    It should say on the bottle:
    10130-89901A
    Automatic Transmission Fluid
    Special Blend
    Matic - D
    is this accurate? 5.3 Liters of engine oil?
  5. #35
    Sep 2011
    Oakville, Ontario
    39
    Quote Originally Posted by GAWDZRA View Post
    It depends on the size of oil filter you use, I picked up 2 very different sized ones. Also, things like oil coolers and extended oil pans need to be considered.
    I don't think I put in quite that much in my r32. Not running an oil cooler or filter relocate and have the larger of the 2 filters on now. I believe I got a bit under 5 bottles in there. Topped it off slowly, started it for a bit, topped it off again.
  6. #36
    GTRCer 91GTRR32's Avatar
    Aug 2011
    Windsor
    71
    I heard putting in 5.5L of engine oil in and then putting in an extra 0.5L of GM engine oil supplement aka GM EOS, is good because of the zinc additive
    Heres a list a buddy of mine gave me for fluids, lemme know what yall think:
    Royal purple 75w90 for diffs - 1.1L front and 2.2L rear.
    Engine oil 10w30 synthetic, 5.5L
    Mix with engine oil ---> GM EOS (Engine oil supplement) 0.5L
    Redline heavy shockproof transmission oil for the tranny
    thats all, the rest of the fluids ill just take from whatever others are saying
    Grand Am DD'er
    GTR Spring - Summer
  7. #37
    GTRCer Xeno-Vibe's Avatar
    Mar 2007
    S.Ontario (London)
    573
    I wonder if RP will eventually make windshield washer fluid and anti freeze? :P
    Double track drift, yo.
    (oo sκylιnε oo)
  8. #38
    Aug 2011
    Windsor
    71
    So gents and gents, quick Q.. Changing my clutch tomorrow and ive decided on 4.0L's of redline heavy GEAR OIL, 75w90. I was having a complication with the guy on the phone, he was confused i was putting gear oil for transmission fluid. Am i right that im going to put 75w90 of redline heavy shockproof GEAR OIL into the tranny?
    He confused me and made me think they are different.. Is there any difference?
    Grand Am DD'er
    GTR Spring - Summer
  9. #39
    Aug 2011
    Windsor
    71
    Sorry for the illegal bump, im getting this stuff today....looking for an answer guys thanks
    Grand Am DD'er
    GTR Spring - Summer
  10. #40
    Mar 2007
    S.Ontario (London)
    573
    Quote Originally Posted by 91GTRR32 View Post
    Transfercase, transmission and differential fluid from what i've read.
    (oo sκylιnε oo)
