Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: R32 GTR Fluid compartment list
    GTRCer Mr. Anderson's Avatar
    Sep 2006
    Squamish, B.C.
    378
    Well I did a little bit of searching and I couldn't find a complete list anywhere of all the different fluid compartments so I think we should get one going here with all compartments and reccomended fluids. - please correct me if I am wrong on anything or if I left anything out and I will edit this post accordingly.
    (sticky?)
    1. Crank case - (engine oil)
    2. Radiator - (coolant)
    3. Brake Fluid - (ATE racing Blue or best DOT)
    4. Transmission - (Royal Purple MAXGEAR 75W90 or AMSoil 75W90 or Redline Shockproof heavy MTL)
    5. Front Differential - (Royal Purple MAXGEAR 85W90)
    6. Rear Differential - (Royal Purple MAXGEAR 80W90)
    7. Transfer Case - (Royal Purple MAX ATF)
    8. Atessa AWD fluid - (Nissan Power Steering Fluid or dextron 3)
    9. Power Steering fluid
    Gregzilla's Avatar
    Aug 2006
    Eadmawntonne
    691
    the FSM reccomends 80W90 in the rear diff and 85W90 in the front, i see no mention of power steering fluid either.
    Sep 2006
    Squamish, B.C.
    378
    cool thanks man.. anything else you can think of?
    what fluid goes in the attessa ressivour? And where the heck is that lol?
    Banned
    Aug 2006
    5,913
    Clutch fluid.
    regular brake fluids work.
    GTRCer Wingnut's Avatar
    Feb 2006
    Red Deer,
    1,478
    ATESSA Reservoir - Nissan Power Steering Fluid.
    Brake Fluid - Best DOT4 you can get, I'm switching to ATE racing Blue on GTR-Dad's recommendation!
    Power Steering - I've read that you should use only NISSAN PS fluid, but I've used the regular stuff.
    Tranny - Heavy Shockproof. I'm running AMSoil 75W90 and it still grinds fourth sometimes...
    90 GTi-R , Full Restoration Project
    91 GTi-R , Full Race Project
    http://i115.photobucket.com/albums/n...phic2short.jpg
    Banned
    Aug 2006
    5,913
    I use ford PS fluid on recommendation of some aussies. Never saw any difference. Got rid of it before i ever had an opportunity to push ps/hicas hard.
    GTRCer RedDragonKnight's Avatar
    May 2007
    Portage La Prairie, Manitoba
    82
    the atessa resivoir in the rear of the car takes power steering fluid. Its for the actuation of the 4wd clutch system, runs of an electric hydraulic pump above the rear diff. The actuator is on the tail of the tranny below the driveshaft yoke.
    Rides -
    Summer: 1992 Nissan Skyline GT-R (Currently parked in garage)
    Winter/Breakdown: 1999 Toyota Tercel CE (only 70,000 KM)
    Feb 2007
    61
    the 4WD fluid is nissan matic D atf fluid... however i think i recal reading that it is the same specification as dexron III. its the matic J stuff thats different.
    As for the power steering fluid it recomends nissas special ps fluid... its still red so its not synthetic and i believe it should be interchangeable with other fluids?
    GTRCer MikeyRHD's Avatar
    May 2007
    Sask
    116
    I was told that all nissans before 2000ish (forgot exact year) use atf fluid for ps
