Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: Skyline Engine MODS Database
  1. #31
    Feb 2007
    Calgary
    87
    VEHICLE: '89 BRN32
    ENGINE: RB26DETT Wiseco 86.5, Carillo rods
    MILEAGE: 110,000 on body, 0 on engine yet
    OIL/WATER PUMP: N1/N1
    OILING SYSTEM: Stock, oil cooler to come
    INJECTORS: Deatschwerks 750 cc
    FUEL SYSTEM: Tomei FPR + rail, SS lines from filter to return
    TURBO SETUP: -5s
    MAP or MAF's: MAP
    INTAKE SETUP: Custom intake w/Apexi filters, Nismo collector (tt pipe) and intercooler hard piping
    INTERCOOLER: Stock
    VALVETRAIN: Tomei Poncam Type B
    HEAD WORK: New oil seals and freshening
    EXHAUST: Tomei knockoff manifolds (buyer beware!), HPI dumps, Apexi N1 downpipe, de-cat, 4" Apexi catback
    BOOST LEVEL: 19 psi
    ECU SETUP: Haltech Platinum PnP
    CLUTCH: ORC Twin plate
    DRIVETRAIN F/R: New OEM tranny
    SPECIAL NOTES: Injectors at 95%, not sure why. More power to come.
    DYNO:
    HP: 489 whp
    TQ: 407 ft/lbs
  2. #32
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    246
    Awesome setup I'm planning to do pretty much the same thing. How come your power band flattens out between 5 and 5500 ish? Is this just wher the second turbo kicks in? (excuse my ignorance)
  3. #33
    GTRCer Billy_Jack's Avatar
    May 2011
    red deer
    102
    That would only happen if he was running a sequential setup
  4. #34
    GTRCer Dakota_gsx's Avatar
    Jan 2010
    Edmonton, Alberta
    173
    VEHICLE: 91 BNR32 Gt-r
    ENGINE: RB26DETT
    MILEAGE: 60,000 on body, 2,000 on my first time rebuilding (second time the engine has been redone, now it is ripped apart again for a third rebuild becuase of a floated valve)
    OIL/WATER PUMP: HKS oil pump, stock water pump
    OILING SYSTEM: Greddy oil block adapter, Greddy oil cooler, Nismo Oil cooler, Extended collar on Jun Crank, Tomei oil pan baffle, Custom tap into head oil gallery with drain back to pan.
    INJECTORS: 650ish cc Denso
    FUEL SYSTEM: Nismo fuel pump, Greddy regulator, Greddy fuel rail
    TURBO SETUP: Nismo street (RS580) on original rebuild, New -5s on current rebuild
    MAP or MAF's: MAP
    INTAKE SETUP: HKS filters with MAFs(not using) and custom piping
    INTERCOOLER: ARC
    VALVETRAIN: BEFORE: supertech valve and guides, HKS cams.
    NOW: Full Ferrea valvetrain with Tomei Cams and gears
    HEAD WORK: Stage 2 port on current rebuild (Lightspeed Innovations port job)
    EXHAUST: Tomei Expreme manifolds, dumps, greddy downpipes, gutted cat, Fujitsubu 3.5" cat back
    BOOST LEVEL: 18 psi
    ECU SETUP: Vipec V44
    CLUTCH: OS Giken triple plate
    DRIVETRAIN F/R: Route 6 5 spd cross mission gearset
    SPECIAL NOTES:Tuned at Lightspeed Innovations (last build)
    HP: 457RWHP
    TQ: 385RTQ
  5. #35
    GTRCer Xeno-Vibe's Avatar
    Mar 2007
    S.Ontario (London)
    573
    you cant just mix and match,certain sizes, designs and materials for parts give better results and respond better in unison together.
    Double track drift, yo.
    (oo sκylιnε oo)
  6. #36
    May 2011
    red deer
    102
    VEHICLE: BCNR33
    ENGINE: RB26DETT .5mm overbore, CP pistons, ACL main and conrod bearings, ARP head and conrod studs, cometic metal headgasket
    MILEAGE: 68000km car 0km engine
    OIL/WATER PUMP: stock water, stock oil with reimax gears
    OILING SYSTEM: stock
    INJECTORS: 660cc denso
    FUEL SYSTEM: undecided
    TURBO SETUP: 2x HKS gt2510s
    MAP or MAF's: n/a
    INTAKE SETUP: HKS hard pipe, shitty HKS mushroom filters
    INTERCOOLER: stock
    VALVETRAIN: stock with TODA power adjustable gears, TOMEI timing belt
    HEAD WORK: stock
    EXHAUST: kakimoto, no cat, unidentifiable downpipes but certainly not stock
    BOOST LEVEL:
    ECU SETUP: HKS FCON V-PRO ECU, HKS EVC
    CLUTCH: NISMO TWIN COPPERMIX
    DRIVETRAIN F/R: unsure, might have lsd, FIELD ETS electronic torque split controller
    SPECIAL NOTES: waiting on tune and rebuild (parts)
  7. #37
    GTRCer bakerman1978's Avatar
    Nov 2010
    sudbury, ontario
    75
    VEHICLE:1993 r32 gtr
    ENGINE:rb26dett
    MILEAGE:120000
    OIL/WATER PUMP:stock
    OILING SYSTEM:stock
    INJECTORS:stock
    FUEL SYSTEM:stock
    TURBO SETUP:stock
    MAP or MAF's:stock
    INTAKE SETUP:blitz cone filters
    INTERCOOLER:stock
    VALVETRAIN:na
    HEAD WORK:na
    EXHAUST:kakimoto 3.5 inch turbo back no cat jun dump pipe
    BOOST LEVEL:14.5
    ECU SETUP:custom tune by rstuning on stock ecu
    CLUTCH:exedy twin plate I was told from seller
    DRIVETRAIN F/R:stock
    SPECIAL NOTES:
    DYNO:
    HP:358.1 rwhp
    TQ:350 at around 3700 rpm
  8. #38
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    VEHICLE: BNR32 GT-R
    ENGINE: RB26DETT (stock bore/internals)
    MILEAGE: 150,xxxkm
    OIL/WATER PUMP: N1 water pump, stock oil pump
    INJECTORS: 800cc deatschwerks
    FUEL SYSTEM: 15 gal fuel cell, 2 liter swirl tank, 1 low press pump, 1 044 bosch external pump, stock fuel rail, Sard FPR
    TURBO SETUP: 2x Nismo (14411-06U00)
    MAP or MAF's: MAP
    INTAKE SETUP: Divided "twin turbo" pipe, HKS mushroom filters
    INTERCOOLER: stock
    VALVETRAIN: stock
    HEAD WORK: 5 thou skim, factory valve lash, metal head gasket, new oil seals and refreshed.
    EXHAUST: 3" turbo elbows, 3.5" side exit exhaust (no cat/res/muffler)
    BOOST LEVEL: Low boost : 12psi Hi boost : 16psi
    ECU SETUP: Apexi Power FC D-jetro, Denso MAP sensors, Apexi AVC-R boost controller.
    CLUTCH: OSG Twin plate
    DRIVETRAIN F/R: stock
    Cooling: 3" JVTR rad, 2x mishimoto fans+ shroud, 10 row custom oil cooler
    SPECIAL NOTES: Car has not been started since build, plan to have it running this week and tuned not to long after. Will update with dyno numbers and updated parts!
    Dyno:
    HP: N/A
    TQ: N/A
