R34 engine swap
Hello,
I was wondering what needs to be done to swap the r32 rb26 with an r34 N1 rb26. Is it a straight drop in or do things need to be changed?
Any replies will be greatly appreciated.
Front Diff/Oil Pan change with your existing one. CAS change with R32/33 type.
next time use
Originally Posted by
bignate
next time use
Let's face it, the SEARCH function on this forum (vBulletin in general) SUCKS......
Try search for R34 to R32 swap and you will get everything related to R34, every SWAP ever talked about on this forum......and 100's of other USELESS R32 posts/threads that waste more time than actually posting a quick answer.
I garuntee it took you more time to insert your SEARCH IMAGE, then it took me to type what I did.....
GTRC isnt the only skyline forum on the net, this info is all over the place. But I do agree, the search function is kind of hit and miss.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
