Results 1 to 9 of 9
Thread: Chassis/Handling MOD Database.
    C-unit's Avatar
    Jan 2005
    Richmond, HongKong
    2,951
    I've seen alot of set up aboutI engine/turbo but rarely seen anyone talks about their suspension set up. I am hoping to start a thread about this topic to aid whoever is needed.
    here is the format:
    Purpose of the car:
    Suspension -
    Spring Rate -
    Control Arms Front -
    Control Arms Rear -
    Bushings -
    Alighment -
    Chassis Reinforment -
    Brakes -
    Notes:
    __________________________________________________ _________
    This is my Set up.
    Purpose of the car: Mostly drifting/ occasional track day. Daily weekend driven.
    Suspension - Aragosta Fully adjustable Std Coilover.
    Spring Rate - Std 7.7kg/mm 5.5kg/mm, Midori 10kg/mm, 9kg/mm for track.
    Control Arms Front - Feast SPL Front upper control arms
    - Nismo Lower Control Arms
    - SPL Front Tension rod
    - SPL V5 tie rod ends
    Control Arms Rear - SPL Upper Control Amrs
    - SPL Traction rod
    - SPL Tie rod
    Bushings - Nismo bushings in lower arms
    - Nismo rear coilover mount bushing
    - Custom Spherical Bearings on rear knuckle
    - SPL solid subframe bushing
    Alighment - I haven't done alighment yet.
    Chassis Reinforment - Tomei 3pt front strut bat
    - 14pt Rollcage with X door bars (not yet)
    Brakes - Brembo 6pot front Monoblock.
    - 355mm 2pcs rotor
    - Brembo R33 rear single piston
    - 350mm V36 rotor
    Notes:
    I am running front GTS-t suspension assembly, RWD conversion.
    S13 no hicas rear subframe with GTR knuckle/upright.
    輝く ヘタクソの星 -- 訓啦柒頭
    Mar 2005
    Calgary
    385
    There is the set up of my 92 R32 GTR
    Purpose of the car: Street Daily Driver
    Suspension - Stock spring and shocks (Like new).
    Control Arms Front - Stock Lower and Upper Arms
    - Nismo Front Tension rod
    - new stock lower inner and outer ball joints
    Control Arms Rear - Nismo Upper Control Arms
    - Nismo Traction Arms
    - New Stock Rear Inner/outer Tie rods
    Bushings - Nismo Rear Subframe Bushings
    Alighment - Home Made (Eyeballed)
    Chassis Reinforment - None
    Brakes - Project u 6pot front(Summer) and Stock(Winter).
    - 324mm 2pcs rotors (Summer) , stock (Winter)
    - Brembo R33 rear dual piston
    - stock rear rotors (I am looking for a set of R33 GTR rear rotors right now)
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    Purpose of the car:
    summer daily driver, regular track car
    Suspension -
    freshly rebuilt HKS fully adjustable coilovers
    which aren't damping adjustable anymore because valves were swapped for self adjusting ones
    Spring Rate -
    front; 8kg/mm
    rear; 6kg/mm
    progressive damping rate
    Front Control Arms -
    KTS adjustable upper control arm
    Cusco adjustable tension rods
    Moonface roll center adjusters
    Whiteline adjustable sway bar
    Rear Control Arms -
    AMS adjustable upper control arms
    Nismo traction links
    Whiteline swaybar endlinks
    Driftworks Total HICAS Eliminator
    Bushings -
    solid aluminum rear subframe spacers
    Nismo steering rack bushings
    Nismo rear diff forward bushings
    Alighment -
    front camber; -2,1°
    front caster; 8.2°
    front toe; 0°
    rear camber; -1.5°
    rear toe; 0.2 in
    Nismo front strut bar
    Cusco rear tri-point strut brace
    Cusco adjustable tension rod pipe
    UltraRace front fender braces
    Front Brakes -
    R33 GTR brembo calipers
    AMS 2-piece 324mm rotors
    Hawk Hp+ pads
    custom brake cooling ducts
    Rear Brakes -
    STI brembo calipers (same as R33 GTR)
    Garage Saurus big brake conversion kit
    Garage Saurus 330mm rotors
    Hawk HP+ pads
    Brakes, system -
    TurboQuip teflon/SS braided brake lines
    Motul RBF660 brake fluid
    Cusco master cylinder stopper
    Notes:
    HICAS system has been fully removed
    Front wheel assembly
    Work Emotion CR Kai 17x9 +38 wheels
    Ichiba 25mm bolt-on wheel spacers
    Rays Duralumin extended nuts
    Yokohama Advan Neova AD07 255/40/R17 tires
    Rear wheel assembly
    Work Emotion CR Kai 17x9 +28 wheels
    Ichiba 15mm bolt-on wheel spacers
    Falken Azenis RT-615 255/40/R17 tires
    RHDskyline's Avatar
    Aug 2008
    L.A
    2,044
    Purpose of the car: Daily Driver
    Suspension - Tein Flex Coilovers
    Spring Rate - Not sure, will find out once i start driving it more
    Control Arms Front - Stock (I believe)
    Control Arms Rear - Stock (I believe
    Bushings - Not to sure
    Alighment - It's aligned lol
    Chassis Reinforment - I'll have to do some searching lol
    Brakes - Stock
    Notes:
    I plan on learning about suspension and everything soon
    http://www.ukdrifting.co.uk/linkpages/nissan/skyline_drifting.jpg
    Quote Originally Posted by m_melen View Post
    GTRC Comic Relief Marke's Avatar
    Feb 2005
    1,893
    Suspension - HKS Hypermax 3
    Spring Rate - 9kg front and 8kg rear
    Upper Links - SPL Parts
    Front Tension Rods - NAMS
    Front Sway Bar - Cusco
    Steering Rack Bushings - Nismo
    Rear Upper Links - AMS
    Rear Sway Bar - Cusco
    Full HICAS delete
    Alignment - Front -3 degrees camber
    +6 degrees caster
    1/8th inch toe out
    - Rear -2 degrees camber
    0 toe
    Chassis Reinforcement/Lightening - Nismo Front Strut Bar
    - NAMS Door Jam/Strut Brace
    - Nismo Subframe Bushings
    - Roll Bar
    - Sparco Circuit Race Seat
    Brakes - DBA Front Rotors, Project Mu Rear Rotors
    - Hawk HP+ Pads front(street/auto slalom) Hawk Blue(track), Hawk HP+ Pads Rear
    - Endless Brake Lines
    - Cusco Brake Cylinder Stopper
    Rollers - Volk CE28N 18x9.5
    - Hankook Z214 275/35/18 (Dry Track)
    - OE Rims 16x8
    - Conti Extreme DW 225/50/16 (Street/Wet Track)
    Others - A/C delete
    - Battery Relocation to trunk
    1989 Skyline GTR
    www.victoriamotorsports.ca
    GTRCer Imation's Avatar
    Nov 2007
    Halifax
    222
    Purpose of the car: DD/Weekend Warrior
    Suspension - STD Standard R3
    Spring Rate - 11kg/mm and 9kg/mm (hard on the back for DD)
    Control Arms Front - AMS
    Control Arms Rear - AMS
    Bushings - subframe solid polyurethane, all remaining oem bushings replaced with energy suspension polyurethane.
    Sway Bars- Cusco Front and Rear
    Driftworks Full Hicas Delete
    Alignment - Front -1.5 degrees camber
    - +5 degrees Caster
    Chassis Reinforment - Cusco front strut bar.
    Brakes - OEM cross drilled rotors
    -Hawk HPS pads
    -Goodridge lines
    Traction - CCW 18x10.5
    - Yokohama Advan a048 265 35 18
    GTRCer Ricky Ricer's Avatar
    Feb 2007
    Littleton, CO, USA
    264
    I'm bored at work so I'm posting my setup
    Purpose of the car: Occasional track days, mainly driven on weekends and sunny days.
    Suspension - Tein HA Coil overs
    Bushings - Stock
    Alighment - Was told by previous owner the alignment was more for street so it doesn't eat tires. As far as I can tell this isn't true. My inner tire does wear faster, from what I can see. I haven't had to replace all four tires yet... It was also supposedly corner balanced, which I don't believe because the left front tire kept locking up at my last track day.
    Chassis Reinforment - Stock strut tower bars and HICAS lock out kit by Tomei
    Brakes - Stock, have Nismo R-Tune pads awaiting install.
    Notes: The way the car handled on the track was great, the original owner did a great job setting the car up, it just needs some fine tuning. I would liken it to a new GTR without the weight. Very nimble, and fun. Only problem I had was engine oil temps getting way too hot after 4 or 5 laps.
    zeldaman's Avatar
    Jul 2008
    Edmonton
    100
    Suspension: TEIN N1 Coil Overs
    Spring rate: not sure
    Front: AMS Tension Rods
    AMS Upper Control Arms
    Rear: AMS Upper Control Arms
    Driftworks full hiccas delete
    Chassis Reinforcement:
    Nismo Front and Rear Strut Bars
    8-Point Custom roll cage
    AMS Aluminum Bushing Kit
    Alignment:
    Front Toe: -0.2*
    Front Camber: -1.6*
    Front Caster: +11.8*
    Rear Toe: -0.1*
    Rear Camber: -5.1*
    Vehicle Track: 0.1
    Jul 2007
    calgary
    466
    Figured Id get in on this despite being a gts, but i find this interesting.
    Purpose of car:
    Most street, some track driving
    Suspenion:
    Tein Type Flex (15 way dampening I believe)
    Spring Rate:
    Front - 6kg/mm
    Rear - 5kg/mm
    *no helper springs
    Front Control Arms:
    AMS tension rods
    Energy/Moog endlinks
    Whiteline Sway bar
    Rear Control Arms:
    AMS RUCAs
    22mm solid sway bar
    HICAS Lock bar
    Bushings:
    AMS solid subframe bushings
    Alignment:
    Front - Camber -2.0 ish
    Caster stock
    Toe 1/8" out
    Rear - Camber -1.0
    Toe 0
    Brakes:
    Goodridge SS brake lines
    Wilwood DOT 4 fluid
    Wheel/Tire:
    Front & Rear 5zigen FN01R-C Hot version 17x9 +15 (no spacers)
    Front tires Im undecided on, leaning towards a yokohama
    and rear tires to match, but typically run fat junkers for the track
    Jesse
    1990 HCR32
    2006 Chev Silverado
