Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Air Intake Piping Size?
    Feb 2007
    Calgary
    87
    Hey Guys,
    I have finally found turbo compressor outlet piping that fits with the -5 turbos and Tomei manifolds (thanks Ricky Bobby!). Now that those fit, the intake piping won't fit. I will be making custom piping no matter what at this point, but my options are:
    1. Use 2.5" piping to squeeze past the compressor outlet piping.
    2. Relocate the power steering fluid resevoir.
    What will be the effect of going to the smaller diameter intake piping? Obviously this will result in more restriction on the air intake, but will it really have any negative effects?
    I haven't been able to find any information on relocating the power steering fluid resevoir, but it's only three lines, can't be that hard. Are there any things to consider in this relocation such as any gravity feed etc. that have to be maintained?
    Thanks for the help.
    Mike
    Apr 2004
    Edmonton, Ab
    545
    What outlets do you have that don't fit?
    Feb 2007
    Calgary
    87
    The stock "Twin turbo" pipe was hitting the exhaust manifold at the front turbo, and I re-used the stock oil and coolant lines for the turbos so I couldn't clock the turbo enough to get clearance. The aftermarket compressor outlet piping I got, unknown brand, made of steel, looks old school, fits like a glove, but impedes on the space for the air inlet piping to the rear turbo.
    Apr 2004
    Edmonton, Ab
    545
    It is probably ebay dumps that are your problem. I've seen them before and they don't fit.
    I think your best option is getting new dumps or porting the stock ones.
    GTRCer Speeddm's Avatar
    Apr 2007
    Grande Prairie
    690
    Definatly epay pipe issue. Just did Tomie manifolds -5 and tomie dumps it all went together fine.
    Feb 2007
    Calgary
    87
    I'm using HPI dump pipes, these aren't the issue. I'm suspecting that the "Tomei" manifolds I bought used and ceramic coated, aren't actually Tomei.
    I'm also going to a MAP sensor and so replacing the stock intake piping. At the moment my plan is to fab some brackets to move the power steering resevoir over an inch to get clearance for 3" intake piping.
    Apr 2004
    Edmonton, Ab
    545
    Hpi dumps are very large so that might be the problem. I would defiantly keep the big dumps and build intake piping.
    I would worry about 2.5 inch piping because it is still bigger than the compressor inlet
    Feb 2007
    Calgary
    87
    The dumps clear no problem, though the flex piece on my downpipe is now 2 mm from hitting the tranny. The compressor inlet is about 2.5" ID, and the universal piping is all 2.5" OD, so there is some difference, but minor. I just don't want to come this far in the build and cause restriction at the intake.
    Apr 2004
    Edmonton, Ab
    545
    If you have the know how or know someone who does why not buy some 3" aluminum piping from vibrant and put a large dimple in it. Make it barely clear and you should be good.
    Feb 2007
    Calgary
    87
    Yeah, I've already got a bunch of Vibrant piping. I'll cut it to fit and have someone weld it for me. Moving the power steering resevoir just slightly will also give me the room needed.
  1. GTR Stock Intercooler/Intake piping
    By MikeRWK in forum Parts for Sale
    Last Post: 09-02-2010, 08:22 AM
  2. WTB: GTR Intake Hard Piping
    By PyreXXX in forum Want to Buy
    Last Post: 04-07-2008, 09:59 AM
  3. intake piping removal
    By falcon in forum General Skyline Discussion
    Last Post: 01-14-2008, 02:22 AM
  4. wtb: aftermarket rb20det intake piping
    By Matty in forum Parts for Sale
    Last Post: 10-24-2005, 09:28 PM
  5. wtb: greddy intake piping
    Last Post: 09-23-2005, 05:34 PM
