Anyone know where there is a video on How to change the clutch out on these cars.
Im able to do the job just need the instructions.
i dont know of a video but there is a skyline manual which should help you
if u need instructions...............i dont think u should attempt
Being built...
No different than doing a clutch on any other car really. If you havent done one before it would be wise to have a friend help that has.
What do you néed to know?
Remove shifter
Remove starter
Remove front driveshaft
Remove rear driveshaft
Remove and plug hicas line
Remove crossmember
Remove bellhousing bolts
Drop tranny and replace clutch
Reverse it.
GTRC-OG
its also wise to drop the tranny crossmember and let the tranny hang to get the top bell housing bolts and starter. Then just bolt the crossmember back up, remove the rest of the bolts and then you can set the tranny on something with wheels and drop the crossmember again.
PS you will need lots of long extensions and be very careful torqueing down the pressure plate.
Thanks, I've done it on a gtst.just wasn't a 100% on the GTR
