Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Skyline misfiring when hot ...
    Apr 2011
    Jonquière
    8
    First of all , sorry for my bad english , I'm french but doing my possible ...
    The car has been stored till 2 years ...
    I bought the car , then I changed ...
    Spark plug , every oils (tr case , engine , tranny , diff frt / rr) gas filter , air filter etcc...
    At first I had BCPR6ES-11 gapped 0.34 and they told me my misfire was due to this but it wasn't the problem
    Second , they told me it was because I had platinum and RB don't like them so I bought BKR7E (copper) gapped to 0.29 and it's still wasn't the problem...
    Third , I Just changed my coils for yellow jacket one , and the problem still persist !
    So now , what could I do ?
    Note: The problem only appears when the engine is hot , when the engine is cool , there is no problem.
    Thanks !
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    318
    Ya my engine does the same thing purrs when cold but misses when hot I'm not too concerned about it though cause it's running perfectly otherwise. But sorry no solution from me
    Jul 2009
    Vancity, BC
    670
    to start off the gap is too small.....
    .3mm? or .3"? spark is too short and .8mm is ideal i guess? wait .3" is .7-8mm
    try swapping with ignitors if u can source one out or something
    2 types misfire...ignition n fuel
    GTRCer bobbo's Avatar
    Aug 2009
    Halifax Nova Scotia
    1,452
    Very simple but expensive. Replace your Ignitor. it's the silver rectangular thing on the back of your coil cover.
    You can also check for codes from the ecu. I can't remember the number but it will tell you if there is an ignition system fault.
    They are about $600 new or any reasonable person sells them used for under $100.00
    You can also convert over to a Z32 ignitor for much less money.
    Jun 2010
    Ottawa
    442
    When you say hot, do you mean the engine is hot or that the air outside is hot? I find whenever my car sits in the hot sun for a few hours and I go to start it it will start and die instantly... Then I try again and give it gas and its fine?
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    2,044
    Quote Originally Posted by bobbo View Post
    In what world do you live in where the ignitor is rectangular!?
    GTRCer GTRADDICT's Avatar
    Jan 2010
    Bathurst NB
    769
    I had problems with my truck (see signiture) on hot days. The heat from the engine would "boil" the fuel in my holley double pumper and fuel vapor would leak in the cylinders and flood the bastard. So meaby for your guys it could be related?
    Edit: Not for OP do... but it sounds like electrical. Heat activated = electrical usually
    03 lancer DD
    68 gmc w/355 cid rice killer
    R33 GTR. The time is near!!
    Aug 2009
    Halifax Nova Scotia
    1,452
    Quote Originally Posted by DarkCaporaL View Post
    It does not have 4 sides of equal length but still has four corners that are right angles. That is a basic rectangle.
    Perhaps pictures will be easier for you to understand?
    http://www.bing.com/images/search?q=...le&FORM=IDFRIR
    http://www.rhdjapan.com/nissan-oem-ignitor-24232
    I had the same problem. Progressed to completely dropping #5 cylinder. Tried a friends, problem solved. Bought another one for $75 and the car has been perfect ever since.
    I believe there is a test for it but you need an oscilliscope if memory serves.
    Jun 2008
    2,044
    Haha I was just kidding. :P
    Apr 2011
    318
    Now I'm assuming the z32 igniter does not bolt right on in place of the original does anyone know of a write up for this conversion?
  1. Misfiring
    By DrewB in forum GTS Tech
    Last Post: 06-02-2011, 11:38 AM
  2. Misfiring RB20
    By Salar in forum GTS Tech
    Last Post: 03-18-2011, 02:09 PM
  3. Misfiring while in boost.
    By Bignoga in forum GT-R Tech
    Last Post: 09-21-2010, 08:33 AM
  4. Misfiring videos
    By sushtsi in forum Media
    Last Post: 09-19-2006, 09:08 PM
  5. My Misfiring system : )
    By calgarygts in forum Media
    Last Post: 01-08-2006, 06:33 AM
