Results 1 to 8 of 8
Thread: BOV constantly going off sometimes?
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    so i have the stock recirculating bov system and i was cruising on the highway, whenever i hit boost a little over ~.5-.6bar i hear the bov system constantly going off until im at 0. once i got off the highway i decided to restart the car....and now its completely fine! my boost restrictors are off and i could easily hit .9bar again
    anyone have a clue on what may be wrong?
    Thanks!
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    BOV got stuck open? May want to clean them if it hasn't been done before.
    GTRCer Snake556's Avatar
    May 2009
    London, Ontario
    1,956
    Had the same issue with a friend's GTR. BOVs got jammed open. Give 'em a cleaning and you should be fine
    '00 Ford Windstar "Rice Killer"
    1994 Nissan Skyline GTR
    Quote Originally Posted by kengeroo View Post
    Nov 2010
    Vancouver
    228
    yeah they were never cleaned before, i wasnt sure how to clean them properly so i never touched it.
    Does anyone know how?
    EDIT. I read to soak it in gasoline overnight, should be a good way to clean it right? (its a oem unit)
    May 2008
    Stouffville, ON
    386
    I think one of your BOV's has probably worn out the diaphragm and is going bad. I had the same symptom with my car. I noticed especially going up hills one would continually choo-choo at low boost pressure. Turned out it had gone bad so I replaced them both and problem solved.
    Toy - 1995 R33 GTR Vspec - Midnight Purple - trust fmic, 98GTR Xenon's, OSG twindisc, BBS LM champs, and more
    Daily - 2004 Dodge SRT-4 Stage 3R
    GTRCer danwit's Avatar
    Sep 2009
    hamilton
    238
    Orrrrrrr you got yourself a boost leak... Could also be a loose clamp etc. that holds vacuum but leaks at 'x' psi
    Dec 2008
    GTA
    439
    Sounds more like the bov sticking
    A boost leak would provide different symptoms
    My old school HKS bov was stuck open and it caused a loss of about 1 psi, my loose clamp on charge piping caused the motor to sputter and was boost couldn't be applied
    Nov 2010
    Vancouver
    228
    Been 2 days since it happened and its running like it never happened lol
    Holding boost up to .9bar just fine, i really hope its just a dirty valve, im pretty sure its not a boost leak as i could hear the choo-chooing when it happened as i was losing boost
  1. FS: Aftermarket Parts will be constantly updating
    By 0piston in forum Parts for Sale
    Last Post: 08-02-2011, 06:03 PM
  2. Replies: 5
    Last Post: 02-03-2011, 04:51 PM
