Results 1 to 10 of 10
Thread: limp mode?
    GTRCer gtst_type_m's Avatar
    Sep 2009
    kelowna bc
    112
    limp mode?
    alright so between start up time and hitting full operating temperature i can not rev past 2500, but when it hits full operating temperature the problem completely goes away, i recently changed my mafs over to the ams z32 and am fairly certain they are wired correctly, fuel pressure is normal (37psi at idle) i have nistune configured to run the mafs. i really dont know where to start to look for this problem any thoughts?
    93 laser sold
    91 skyline gtst totaled
    92 skyline gtr current
    Sep 2009
    kelowna bc
    112
    no one?
    93 laser sold
    GTRCer Turboholic's Avatar
    Mar 2009
    GARNER, NC USA
    91
    Had same problem once I installed my AEM. AEM provided new pickup wheel for my CAS (Cam Angle Sensor). Had CAS rebuilt with new wheel and problem solved. My guess would be replace CAS.
    Sep 2009
    kelowna bc
    112
    alright so AEM sells the parts to rebuild the CAS, do i need to call the and special order it or do they sell them online
    93 laser sold
    GTRCer jrhdohc's Avatar
    Oct 2010
    Yokohama
    69
    Nissan ecu won't read the AEM CAS wheel correctly.
    Nissan/Hitachi uses 6 and 360 holes for the optical sensor to read.
    AEM/Motorola (left over from Honda design) uses 24 and 1 hole configuration.
    One is not better than the other. Just compatibility issues. if you're lucky you can program AEM to work with Nissan CAS. But AEM CAS won't work with Nissan ecu... even with Nistune... atleast never seen or heard of it being possible.
    Does your ecu show any codes?
    did your car ever run correctly with your new set-up?
    Sep 2009
    kelowna bc
    112
    it shows no codes i did run correctly after the new mafs where put in and runs correctly when it hits full operating temp, i dont think the cas would make a difference in engine temp, the way i wired the mafs is
    2 - b
    4 - c + d
    5 - e
    first time it was
    2 - b
    3 - c
    4 - d
    5 - e
    but that didnt work correctly and these where the 2 ways i found of doing it
    93 laser sold
    Mar 2009
    GARNER, NC USA
    91
    I have the stock wheel that was removed from my cas to install the AEM wheel. If you want it let me know and I will come up with a price. I also have an extra CAS if needed. I had recommended replacing CAS.
    Sep 2009
    kelowna bc
    112
    but as jrhdohc said ur problem was because u had an aem ecu installed without the aem cas wheel, im not sure if my cas wheel is shot ill let you know if i need one asap tho
    93 laser sold
    cortexx's Avatar
    Apr 2010
    Turkey Point , Ontario
    1,070
    Well if your engine is cold and you dont have the fuel correction setup for the lower engine temps it will be lean as hell while warming up , this will cause alot of coughing and farting until you reach proper temperature.
    Sep 2009
    kelowna bc
    112
    soo you think i have a problem in open loop mode? because it can be a few degrees before full operating temp and the problem dosent improve untill it hits full operating temp
    93 laser sold
  1. Possible LIMP Mode?
    By Madskyline in forum GTS Tech
    Last Post: 11-13-2011, 10:12 PM
  2. Limp Mode.......need help & advise!
    By 326_godzilla in forum GT-R Tech
    Last Post: 10-06-2011, 05:29 PM
  3. r33 Gtr limp mode?
    By cory in forum GT-R Tech
    Last Post: 12-18-2010, 01:07 AM
  4. gtr limp mode - now not starting... help :/
    By thieves in forum GT-R Tech
    Last Post: 11-29-2010, 04:53 AM
  5. Limp mode?
    By Mitch01 in forum GTS Tech
    Last Post: 03-27-2007, 07:33 PM
