I bought an engine without the turbo's and lines. I bought a set of oem rb26 turbos and a set of coolant lines off another member. Some of the coolant and oil lines I had and some that I bought were bent and not usable.
Anyway I don't have either coolant return hard pipe or fittings from each turbo to the big T between each turbo for the coolant. I have a repair manual but it doesn't give me any size of fittings or a decent pic. So what is suppost to be in the coolant return from the turbos?
It looks like a 14x1.5 fitting into the turbo, then into a 16x1.5 fitting attached to a 10mm hard pipe then goes into the big T, same for the rear turbo. Is this correct? Does anyone have a good pic of what I'm suppost to have. I have the rear coolant return hard pipe but it does not thread into the turbo because the fitting is to big. Is there a reducer like a 16 to a 14x1.5?
LinkBack URL
About LinkBacks
