Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By TyrelLee
Thread: Leaking Injectors - How to Fix?
    GTRCer aN4rk1's Avatar
    May 2010
    Mississauga
    1,042
    Ok guys,
    I did a once over of my car yesterday and found my injectors were leaking. I want to fix them, I will need new o-rings right? Is there a tut on how to do this? i tried googling, no go
    GTRCer Smilez's Avatar
    May 2009
    Edmonton
    124
    1. get o-rings from nissan dealership. they were cheap last time i did it.
    2. take out metal clip on each injector. careful not to drop down below! use some needle nose pliers.
    3. take out 2 bolts holding fuel rail.
    4. pop the injectors out of the head and jimmy past the fuel rail.
    5. slide the new o-rings on.
    6. put everything back.
    done in under an hour.
    1991 Nissan Skyline GTR (main)
    2007 Toyota Tacoma TRD 4 door (baby wagon)
    May 2010
    Mississauga
    1,042
    AWESOME THANK YOU!! Do you have the part numbers for the orings?
    GTRCer Marus92's Avatar
    Jun 2010
    Bathurst NB
    854
    Injector O-rings 16618-78A00, 16635-78A00, 16636-V5000
    Spout, middle (rail), tip (ITB body)... not sure of the order though. They're off a KA24E (89-90).
    You could of used the search function... I had made a post about it back in june 2010. One of my first posts actually. BTW, your hats may (probably) are leaking. Better pressure test the injectors too.
    Jun 2011
    Red Deer
    112
    Make sure to blow the dirt out around the injectors so it doesnt drop I to the ignition chamber. When your putting them in put the injectors into the phenum then line up the injectors. Don't push them in all the way into the rail just tighten the two bolts bit by bit to let them go in themselves. If that makes sense.
    TyS likes this.
    Jan 2009
    Dundas
    601
    Sometimes the injector itself is just crap. You can try getting the rings but if it still leaks. Buy different injectors. Used stockers can be had for $20 a piece from the right source.
    Jan 2009
    Dundas
    601
    Quote Originally Posted by Smilez View Post
    Missed step 2. Start car and pull fuel pump fuse! Lakes life easier.
  1. water leaking everywhere.
    By stephansmith in forum GTS Tech
    Last Post: 06-04-2011, 12:24 AM
  2. ABS is leaking!!!
    By deo13 in forum GT-R Discussion
    Last Post: 03-13-2008, 09:42 PM
  3. Leaking oil...
    By waldo in forum GTS Tech
    Last Post: 07-02-2007, 12:26 AM
  4. ABS Leaking
    By mikes_ca in forum GT-R Tech
    Last Post: 05-14-2007, 07:44 PM
  5. Fixing leaking injectors??
    By JBNR32 in forum GTS Tech
    Last Post: 08-11-2005, 02:02 AM
