Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Hicas wobbling?
    GTRCer ChezoGTR's Avatar
    Apr 2011
    Winnipeg
    63
    Hicas wobbling?
    So as im driving my rear end seems to have a mind of it's own and I'm pretty sure my hicas is acting up and activating when it's not suppose too. Any suggestions other then deleting it?
    DRIVE FOR THE LOVE
    1995 NISSAN SKYLINE GT-R R33 V-SPEC GOHAN
    GTRCer Marus92's Avatar
    Jun 2010
    Bathurst NB
    854
    Check your rear ball joints if you're not getting a code (dash warning light), especially if the wobble is at <80kph since the system only engages past that speed.
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    My HICAS acts up every so often. If I'm on the highway doing over 80 km/h, the rear end steps out and the car crab walks until I get back down below 80, at which point the rear wheels turn back to neutral and the car is no longer walking sideways.
    I think a wobbling motion would be more ball joint/something is worn related.
    GTRCer Ricky Ricer's Avatar
    Feb 2007
    Littleton, CO, USA
    264
    I was having this problem above 80mph. I put in a delete bar. HICAS is retarded. Nobody needs that garbage.
    Apr 2011
    Winnipeg
    63
    anyone know where i can pick up a delete bar and what they normally run for?
    DRIVE FOR THE LOVE
    Feb 2007
    Littleton, CO, USA
    264
    ebay bar is cheap and works.
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,894
    less then 100 bucks
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    Are you playing to much Dubstep?
    lmao im just kidding. Sorry.
    Yeah I would just get rid of the whole system straight up. One less thing to worry about. Plus there's advantages with deleting it. Im trying to find a lock bar as well. I saw them for 50$ at one point!
    Goodluck
    May 2009
    Ottawa, ON
    197
    mine does the same, my hicas light will flicker for a second and my rear end will wobble, feels like its gonna shoot you across the road, first time it happened i nearly **** my pants
    Apr 2011
    Winnipeg
    63
    its @#$%ing scary! especially when you're doing 140 kmh and she starts to do the watoosie. also i found something cool just a while ago while i was doing hicas research. you can enter a hicas diagnostic mode. heres how i did it and its blody cool you can actually see the rear tires move. with the steering wheel centered turn the car to the run position (enigine running) and turn the wheel from left to right 5 times then bress the brake 5 times. hicas light will start to flash. to enter full diagnostic mod, while the hicas light is flashing creep the car forward about 5 meters WITHOUT exceeding 10 kph. your hicas light should now be flashing a code starting with long flashes then short flashes followed by 10 short flashes. to find your code if present just google hicas codes. pretty neat stuff
    www.jmdlegion.com/assets/skyline_book.pdf <----- this is the little write up i found it on. also tells you how to enter your ecu diagnostic and how to reset your stock ecu to factory settings
    DRIVE FOR THE LOVE
  1. FS: Tomei HICAS Lock 2 (Eliminates HICAS)
    By dk89 in forum Parts for Sale
    Last Post: 05-10-2011, 08:51 AM
  2. Replies: 12
    Last Post: 04-05-2011, 09:32 AM
  3. HICAS and Super HICAS
    By SxyBeast in forum GT-R Tech
    Last Post: 07-07-2008, 01:31 AM
  4. HICAS and Super HICAS
    Last Post: 06-29-2008, 09:15 PM
  5. Hicas light on, hicas removal bar in place.
    By Inline Slut in forum GTS Tech
    Last Post: 12-05-2006, 11:19 AM
